VSS for 92 silverado
Forum Name: Mobile Video, GPS, and Navigation
Forum Discription: Mobile Video Head Units, DVD Players, LCD and TFT Monitors, Navigation, GPS, PS2, PS3, XBox, etc.
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=80638
Printed Date: April 18, 2026 at 7:17 PM
Topic: VSS for 92 silverado
Posted By: executioner
Subject: VSS for 92 silverado
Date Posted: July 23, 2006 at 9:45 AM
I need to locate the VSS wire and the reverse wire on a 1992 Chevrolet Silverado so I can install my N2 correctly. Can anyone give me the color and location of these wires. Thanks
Posted By: KarTuneMan
Date Posted: July 23, 2006 at 8:10 PM
Date Posted: July 23, 2006 at 8:47 PM
So according to this I dont have a VSS wire? What do I use instead? What about the Reverse? Thanks
Posted By: sparkie
Date Posted: July 23, 2006 at 8:53 PM
The VSS wire is located in the electrical center on the firewall above the driver's kick panel. There is a cavity in the top left corner labeled Orange. The middle pin is the VSS connection you need. The reverse wire will be light green. You may be able to find it in the same area, but I can't remember. It will go to 12 volt + when the truck is in reverse.
sparky
