N2 nav problems, freezing up
Forum Name: Mobile Video, GPS, and Navigation
Forum Discription: Mobile Video Head Units, DVD Players, LCD and TFT Monitors, Navigation, GPS, PS2, PS3, XBox, etc.
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=82764
Printed Date: December 22, 2025 at 2:41 AM
Topic: N2 nav problems, freezing up
Posted By: gmc_zr2
Subject: N2 nav problems, freezing up
Date Posted: September 11, 2006 at 9:14 PM
I have the AVIC-N2. I am having a problem with it switching to NAV mode. I have done the reset on the front of the unit.  Forced software flash and cleared the memory.
It does not "switch" navigation mode when I insert the Nav DVD. However if I put the dvd before doing anything else it will read the nav dvd and allow use of all buttons. The speedo and gauges also do not come up...only a screen with the regular background.
If I take out the nav dvd (while it is actually working) and listen to a cd...when I try to put the navi dvd back in it does nothing. The when I click the AV button it will go to whatever the nav screen was previsouly on. But will not change and none of the buttons work (screen or unit) The map will not zoom, move, or move along the road. It pretty much freezes up. However I still have all functions for the rest of the radio. FM/AM radio, XM tuner, and TV tuner all work.
Normally when I insert the Navi DVD you can hear it whirling around reading it, but now it does not do that. (only time it does is when you first boot it up)
GPS antenna signal is full; dvd is not strached at all.
So in conclusion the navi only works when the radio is turned on with the dvd in. After that NAV does not work, map does not move; Nav screen freezes whether on the menu, map, or gauges. Does not read touch screen buttons or unit buttons. However function of buttons/touchscreen of the rest of the unit work. (CD/XM/TV)
It works if the nav dvd is the first in when the system is turned on....once i take it out the unit needs to powered off to read the nav dvd again.
Thanks,
Kevin
Posted By: gmc_zr2
Date Posted: September 12, 2006 at 8:35 AM
It seems as though the memory stays full or doesnt work at all.  It will not switch to memory nav mode.  I tried a backup mempory clear.  It work one time with memory nav mode.  After that it did not work.
Can I clear out all those other options on the service screen?  Such as the gps memory one?  or clear any one those files?
Posted By: full_flex
Date Posted: September 19, 2006 at 8:06 PM
interesting, i had a similar problem with the AVIC-N2 at one time..  i was having problems with the unit locking up and freezing, the memory nav wouldn't work once i took the disk out either.. this was while using the 1.2v disks..  i went back to using nav disk version 1.1 and the problem went away..  seems as though the unit didn't work well with the updated disks.. hope this helps.
Posted By: gmc_zr2
Date Posted: September 19, 2006 at 8:10 PM
Yup sounds like the same problem...however I have not changed disks.  I guess I will send it back to pioneer when I have time.
