vss for 06 altima
Forum Name: Mobile Video, GPS, and Navigation
Forum Discription: Mobile Video Head Units, DVD Players, LCD and TFT Monitors, Navigation, GPS, PS2, PS3, XBox, etc.
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=83438
Printed Date: May 01, 2026 at 6:58 PM
Topic: vss for 06 altima
Posted By: djtripz
Subject: vss for 06 altima
Date Posted: September 27, 2006 at 8:23 PM
can anyone help me with this??? i tried any wire except black pink or red at any ignition coil.. this gave me a reading, but the avic-d2 read that i was going 20 miles an hour in park.. which messed up my navigation... also, i only have the standard radio, no bose no midline, so theres no pink or black wire at my radio harness.. any help pleaseeee... also, i think my gps thinks im going backwards even tho my reverse wire is hooked up.. .right now i don't have the vss hooked up n e more.. and when i put in an address.. it will highlight the road behind me.. its really weird.. any input on this would be nice too.. again.. its an 06 altima, automatic, 4 cylinder, avic-d2
Posted By: shaggy12volt
Date Posted: September 27, 2006 at 10:17 PM
use the pink / YELLOW behind the instrument cluster | Speed Sense | pink or black | | radio harness (Midline or BOSE only) | | Notes: On vehicles without the 5 speed automatic transmission, can also use blue / YELLOW behind the instrument cluster. |
------------- The Shagmaster
1999 Chevy Suburban 15" lift sittn on 22's sets 7'5"
1992 Chevy Astro Van all Bagged out Dubbed THE SUICIDER
Installing for over 18 years Looking for empolyment NOW send PM for resum
Posted By: djtripz
Date Posted: September 27, 2006 at 11:41 PM
any ideas how i can get behind there?? i got upside down under the sterring wheel and there r a lot of wires all taped up together and a lot of them were pink, how do i know which is the right one? i gotta test them all??
Date Posted: September 27, 2006 at 11:53 PM
im soory is blue / YELLOW typed it wrong it might be easyer to pull out the cluster
Posted By: djtripz
Date Posted: September 28, 2006 at 12:26 AM
isn't that not for 5 speed automatic?? if it is the right wire.. would u be able to tell me how to take out the cluster?? does it just pull out? cause i don't wanna break n e thing, its not my car
Posted By: Mike M2
Date Posted: September 28, 2006 at 9:32 PM
Blue yellow is it at the cluster on all model Altimas now. To get the cluster out, the dome shaped section above the cluster pops off(just pry it upwards). There's two screws under it and there's two screws under the cluster just above the steering shroud behind the rubber. You'll find a single plug on the cluster with the correct wire....
------------- Mike M2
Tech Manager
CS Dealer Services
Posted By: djtripz
Date Posted: September 29, 2006 at 12:48 AM
thanks so much, im going to check it out tomorrow. i hope it works. i heard that tapping into the vss on nissans messes with the transmission. is this true?? this is what some installer told me. any input on this?
Posted By: Mike M2
Date Posted: September 29, 2006 at 2:12 PM
I do at least 10 Altima's a month for a dealer near here, never had an issue. It's actually one of the easiest Navs to install, the kit fits well. You can even get the handbrake wire at the cluster while getting the VSS. Totally not true, won't hurt a thing...
Tech Manager
CS Dealer Services
Posted By: djtripz
Date Posted: September 29, 2006 at 2:43 PM
hey man, i just wanna thank u so much... everything came out exactly how u described, i tapped the wire, closed everything up, 5 minutes later the nav was working perfectly. thanks again, i appreciate it. let me know if i can ever help you with anything!!
Posted By: Mike M2
Date Posted: September 29, 2006 at 4:08 PM
Glad to help!
Tech Manager
CS Dealer Services
