03 Escalade Reverse signal
Forum Name: Mobile Video, GPS, and Navigation
Forum Discription: Mobile Video Head Units, DVD Players, LCD and TFT Monitors, Navigation, GPS, PS2, PS3, XBox, etc.
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=86131
Printed Date: April 27, 2026 at 5:30 PM
Topic: 03 Escalade Reverse signal
Posted By: Firstnbass
Subject: 03 Escalade Reverse signal
Date Posted: November 24, 2006 at 2:24 PM
where, and what color for Navigation, aside from the typical "At the reverse Bulb" thanks, please IM response to firstnbass on AIM i am in the middle of the install and i will not have time to look at the forum during the process thanks
*ALwaYs KnoW YoUr SaLEsmAN!!*
Posted By: johnmax
Date Posted: November 24, 2006 at 3:49 PM
Jeez I guess i wont post the answer since you only want it via AIM and I dont run that here.  Anyway its green at the BCM behind drivers dash, plug on the right. I havent hooked up reverse to a navigation system in a long time. Not necessary.
Date Posted: November 26, 2006 at 9:24 AM
Well I checked back, haha
Installed the Clarion Max, and Nav it checks system to see all connections are proper, when a custom runs this test he will call and say, "It doesn't recognize the reverse connection" Then ill be taking the truck apart again to connect a wire that he doesn't need, and is not necessary.
Anyways now i cant get this thing to locate itself, this is the first clarion unit i put in usually i do the Eclipse AVN line, but this one just wont pick up the vehicle location. Any help here?
Also Id like to see the LAW that states it is illegal to bypass the E-Brake wiring, as I found in another post with a question about this unit.
https://www.the12volt.com/installbay/forum_posts.asp?tid=84667&KW=max675vd
It may be illegal to operate a vehicle with a screen in the view of the driver, but nowhere is it illegal to bypass the connection. BB and CC may find it to be a problem when lawsuits are involved, but Lawfully, what code, and subsection can i be charged for making that connection? Thanks
