video interference
Forum Name: Mobile Video, GPS, and Navigation
Forum Discription: Mobile Video Head Units, DVD Players, LCD and TFT Monitors, Navigation, GPS, PS2, PS3, XBox, etc.
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=90630
Printed Date: March 30, 2026 at 9:22 AM
Topic: video interference
Posted By: beardown1
Subject: video interference
Date Posted: February 18, 2007 at 9:11 PM
Hello all,
I have installed an underdash dvd player with built in FM Modulator that plugs into my lighter.  I also installed an overhead monitor.  When my vehicle (99 Suburban) is off, everything works great.  As soon as I start the car though, there is so much interference that the screen goes blank and displays "no signal".  Any suggestions on what to do in order to reduce the interference?   (I installed a high quality moble video cable thinking that might help, but with very little improvement)  Any help would be greatly appreciated.  Thanks.
Posted By: swerve
Date Posted: February 19, 2007 at 12:20 PM
get a power line filter 15amp and wire it in. should do the trick, if it doesnt double check where you got power and grounds from and maybe try new power sources.
git yer swerve on!
Date Posted: February 19, 2007 at 3:45 PM
Hey thanks for the response swerve.  Any idea where I can get one of the power line filters that you suggested?
Posted By: swerve
Date Posted: February 19, 2007 at 3:54 PM
big box stores usually have them in the car audio departments or you can try online
git yer swerve on!
Posted By: INSTALLER_MSS
Date Posted: March 07, 2007 at 12:31 AM
radioshack has them for use with CB radios.  also check to make sure your rca cable you used for the video signal is not a "twisted pair rca" or it will give you trouble similar to that.  make sure the video signal cable is run away from larger power wires and computer related devices (BCM, etc.) and away from the fuse panel.  and check for a good ground and that the power is full 12 - 14 volts
"If a man made it, another can modify it...it just takes some thinking."
"If you ask questions, you're a fool for 5 minutes; if you don't, you're a fool for a lifetime."
