vss for 2004 ford f250 sd
Forum Name: Mobile Video, GPS, and Navigation
Forum Discription: Mobile Video Head Units, DVD Players, LCD and TFT Monitors, Navigation, GPS, PS2, PS3, XBox, etc.
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=92527
Printed Date: March 26, 2026 at 2:04 PM
Topic: vss for 2004 ford f250 sd
Posted By: riggz
Subject: vss for 2004 ford f250 sd
Date Posted: April 04, 2007 at 4:36 PM
I've searched and searched and the answers I find are that the VSS wire for my Ford F250 Super Duty is a grey wire w/ a black stripe. I've located wires in 2 locations matching this description. However neither one appear to work for my navigation unit. The two locations I have found are:
Driver's side engine compartment in a bundle of wires passing thru the firewall.
Passenger's side engine compartment coming from a component mounted to the inner fender.
Can anyone here provide another location or if you've installed one before the exact location and any images?
Thanks!
-=riggz
Posted By: KarTuneMan
Date Posted: April 04, 2007 at 6:28 PM
VSS WIRE Gray/black At Powertrain Control Module   8000ppm
 Pin-68 on the F150 and F250, Pin-58 on the F250 and F350 Superduty. The PCM is located on the driver's side of the firewall.
Posted By: caadoptees
Date Posted: May 29, 2007 at 6:20 PM
posted_image Pin-68 on the F150 and F250, Pin-58 on the F250 and F350 Superduty. The PCM is located on the driver's side of the firewall.
Would this be the same for an '03 also? I have a feeling things did not change that much between '03 and '04, but I have been wrong before.
Thanks!
Posted By: Mike M2
Date Posted: May 30, 2007 at 9:12 PM
Here's what i have for 03 and 04...
Speed Sense gray/black    instrument cluster or
Notes: Also found at the radio on vehicles that have the in-dash CD changer.
Mike M2
Tech Manager
CS Dealer Services
