07 gmc yukon
Forum Name: Mobile Video, GPS, and Navigation
Forum Discription: Mobile Video Head Units, DVD Players, LCD and TFT Monitors, Navigation, GPS, PS2, PS3, XBox, etc.
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=95451
Printed Date: May 14, 2026 at 2:37 PM
Topic: 07 gmc yukon
Posted By: jrkear
Subject: 07 gmc yukon
Date Posted: July 08, 2007 at 9:26 PM
Need help find correct power under dash. I am instaling Vizualogic headrest  and have everything behind glove box. I need to find a contant power and ground. It also ahas an optional Green parking wire not sure what that is?
Thank You, Lee
Posted By: CTOH
Date Posted: July 08, 2007 at 11:02 PM
Take the driver kick panel off, there is a white or gray plug that is about 2" wide clipped to the metal behind the hood release, unclip it and you will see a green solid wire next to a purple wire, use this as your 12v Ign, take the fuse panel door off and you will see 5 or 6 RED / white wires going into one plug, use the largest of these as your constant,,,
