01' Silverado, Clifford RS 3.5
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=54848
Printed Date: May 14, 2024 at 5:18 AM
Topic: 01' Silverado, Clifford RS 3.5
Posted By: Slammed01
Subject: 01' Silverado, Clifford RS 3.5
Date Posted: April 26, 2005 at 3:32 AM
sometimes when I remote start the security light goes on but it starts fine.......could this be related to my alarm? If so, what could it be? My Air Commander Air compressor for my AirBags might be throwin' oil on the wire goin' to my computer for my Remote Start Im confused..lately sometimes my truck when I turn the key or doin a remote start it will start/run for about 2 seconds then shut off...wont hold idle..it acts like its not getting any gas. Could this be related to the alarm wire goin to the computer and gettin a small amount of oil on it? Sometimes I have a burning smell...........thanx guys!
Posted By: daniel2002p
Date Posted: April 26, 2005 at 10:18 AM
how was the alarm installed?
------------- 2005 Toyota Corolla S
1.8L VVT-i I-4
Always double check your wires with a DMM!!!
Do Not Use A Test Light!!!
MECP Certified Installer!
Best Buy 665 - IN IT TO WIN IT! TEAM MOBLE!
Posted By: thepencil
Date Posted: April 26, 2005 at 10:33 AM
"sometimes when I remote start the security light goes on but it starts fine.......could this be related to my alarm?" Yes, if you mean your factory alarm. More specifically, it might be the PASSLOCK MODULE. Try replacing the Passlock module and see if that will remedy the problem. "Sometimes I have a burning smell" This can be anything and not related to the remote start. ------------- Be careful whose advice you buy, but be patient with those who supply it.
Date Posted: April 26, 2005 at 11:44 AM
Whatcha mean? It was installed by soldering.....if thats ur Question......Ive had it since october without a problem!
Date Posted: April 29, 2005 at 9:42 PM
When I remote start the security light goes on but it it starts.....in my 2001 Chevy Silverado. What could be causing this? Thanx!
Posted By: auex
Date Posted: April 29, 2005 at 9:53 PM
Improper installation of bypass module. Or bad module. I am betting on the first one.
------------- Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
Date Posted: April 29, 2005 at 10:19 PM
I had it installed since October and it recently started doin' this........
Posted By: auex
Date Posted: April 29, 2005 at 11:49 PM
Well then it could be a bad ground(most likely), corroded connections(least likely unless you used t-taps), or the module could have gone bad(second most likely).
Date Posted: May 01, 2005 at 3:38 PM
Aight....friends gunna come check the grounds and such......! Anyone have a wiring diagram for a 2001 Chevy Silverado? Its a clifford alarm RS3.5 btw....
Posted By: Velocity Motors
Date Posted: May 01, 2005 at 6:55 PM
You asked for it the last time and here it is again: https://www.the12volt.com/installbay/forum_posts.asp?tid=41452&KW=2001+Chevy+Silverado Use the search feature or use the diagrams link. It will save time for you next time. ------------- Jeff
Date Posted: May 02, 2005 at 5:47 PM
cool thanx sorry, posted that awhile ago ;)
Date Posted: May 02, 2005 at 5:56 PM
Just searched for the wiring diagram for the Clifford RS 3.5 and couldnt find it......anyone have it? I just wanna print out a copy for my alarm to go over. Thanx again.....! Thats the only diagram I need for my truck in the other post?
Date Posted: May 02, 2005 at 6:03 PM
On my 01' Silverado and my Clifford RS 3.5 when I do a remote start/unlock my foglights come on lol, which would mean to dome light is wired to the fog wires right? Also when I turn on my foglights my domelights will go on when I push the button. I used to have a out of ignition 10 minute delay where if I have the keys out I can still have the radio on for 10 minutes then it will automatically shut off........It seems that this feature doesnt work! Then if I hit the fog button with the keys out of the ignition it will turn off the power like its supposed to do after 10 minutes. Does anyone know what would cause this and how to enable it again? Thanx for all the help its appreciated!
Posted By: KarTuneMan
Date Posted: May 02, 2005 at 6:32 PM
where did you get your parking light wire? for the light flash.....AND, did you wire it up for domelight supervision?
Date Posted: May 03, 2005 at 1:11 AM
It was all under the dash i believe......since a friend who owned a shop did it :).....the remote start wire went to the computer under the hood tho....
Date Posted: May 03, 2005 at 1:14 AM
Posted By: Calgarysouth
Date Posted: May 03, 2005 at 10:04 AM
what wire went to the computer under the hood?? the only things out there are tach (at a coil or injector) and the hood pin. the rest of the install is at the bcm and the ignition harness. have you checked the fuses?
Posted By: Ravendarat
Date Posted: May 03, 2005 at 10:23 AM
You can get tach at the ecm under the hood, thats probally the wire running there. Why arent you taking this back to your friends shop if they did the install. I am sure that they could fix this problem fairly easily. I mean you can do it your self, it sounds like you just need to reconfirm and relocate where the parking lights and the domelight supervison light goes, but I wouldnt mess with someone elses work if I was you.
------------- double-secret reverse-osmosis speaker-cone-induced high-level interference distortion, Its a killer
Date Posted: May 03, 2005 at 10:26 AM
great point.....it's a lot easier for the person who did the job originally to fix a problem.
Date Posted: May 03, 2005 at 10:32 AM
HELLO..... -------------
Date Posted: May 03, 2005 at 4:58 PM
Yea hes gunna go over everything, I just wanna make sure thats what my problems sound like. I got the wiring diagram for my truck now does anyone know where to find a clifford rs 3.5 wiring diagram for the alarm itself.?....I doubt he still has his. Thanx, Adam
Date Posted: May 05, 2005 at 12:54 AM
any luck on a wiring diagram for the clifford 3.5 RS since I have to have surgery tomorrow and wanna get it fixed when Im off on my downtime. Thaaaaaaanx :)
Date Posted: May 25, 2005 at 1:00 AM
Hey guys gotta update..2001 Chevy Silverado Ext Cab/Clifford RS 3.5...sometimes when I remote start the security light goes on but it starts fine.......could this be related to my alarm? If so, what could it be bad passlock ground/module? ..lately sometimes my truck when I turn the key or doin a remote start it will start/run for about 2 seconds then shut off...wont hold idle..it acts like its not getting any gas WTF!Seems to start fine cold...Im gettin over surgery and turn it over every few days so it doesnt kill the battery... TODAY- I went and picked my cousin up from school, I backed outta my garage and security light came on. I turned the truck off and restarted it and the light went away. So I drove for about 20 minutes and parked at my aunt and uncles and shut my truck off......came back about 45 minutes later and hit me remote start button and it didnt start. Tried the key and samething. So I tried startin it for 2-3 minutes and nothin :( .....so I jumped in my uncles truck and came back 2 hours later and it started first try. My uncles friend said maybe fuel pump but why would it work until the trucks warm? Grandpa said seems like a short..... Would this be the diagnosis of alarm actin weird or passlock module? Thanx, any help appreciated!
Date Posted: May 26, 2005 at 2:58 PM
aright so my friend is comin' over next week and he said hes gunna unhook the 555L Passlock module to see if thats it...and solder up ,my ignition wires so as if the module was never there...so if thats the problem (passlock bypass) and he does this that should cure the problem correct? I dont mind to loose the remote start for a week or so to try! Thanx guys....
