2003 silverado compustar
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=137608
Printed Date: April 09, 2026 at 4:04 AM
Topic: 2003 silverado compustar
Posted By: 36isherwood
Subject: 2003 silverado compustar
Date Posted: November 05, 2014 at 8:52 PM
Installing a compustar 2way with a blade al on a 2003 silverado hd wondering what wires need to be hooked up besides data wire have never installed on a gm I work at a ford dealer any help would be appreciated
Posted By: kreg357
Date Posted: November 05, 2014 at 9:32 PM
Should be real close to this Pictorial on a sister vehicle :   https://www.the12volt.com/installbay/forum_posts.asp?tid=133000
Posted By: blanx218
Date Posted: November 06, 2014 at 8:30 PM
When using idatalink hook everything up that their guide tells you plus your standard remote start connections
Date Posted: November 06, 2014 at 8:53 PM
So I finished my install compustar 7200 with blade al hooked up both ign wires and start , 12v and accessory truck starts but when I look at the dash display says 4x4 fault and message doesn't go away until I shut vehicle off and start again. Did I miss something? Thx
Posted By: blanx218
Date Posted: November 06, 2014 at 9:09 PM
Check the jumper for ign2/acc. Make sure it's set for ign2
