Ungo Remote Start Wiring
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=147
Printed Date: May 12, 2026 at 2:09 PM
Topic: Ungo Remote Start Wiring
Posted By: m3kgtguy
Subject: Ungo Remote Start Wiring
Date Posted: March 26, 2002 at 8:13 AM
Ok, got a wiring diagram for my Clarion Ungo MS-2005 Car Alarm... I have installed a few alarms before, but I have no clue on some of the more advanced stuff this alarm offers (for instance, it has all built in relays, and also remote start relays integrated...)
Anyways...
Need some wiring help here...
Starter Output - (I am guessing this goes to the starter circuit) Accessory Output - (No clue here) Ignition 1 Output - Not sure on this one... (maybe the "keep the car running wire") Ignition 2 Output - Not sure here either...
Door Trigger - Why is there positive and negative inputs for door triggers - is this a one or the other type thing????
Thanks for any help....
-Cody
Posted By: Velocity Motors
Date Posted: March 26, 2002 at 8:29 AM
- Starter Output - Goes to your starter wire under the dash
- Accessory Output - Goes to your primary accessory wire that controls your A/C and heater controls
- Ignition 1 Output - This wire has 12 volts with the key in the RUN and CRANK positions only. Some cars have more than one of these wires and are located in the ignition harness by the steering wheel
- Ignition 2 Output - Some cars need a second ignition wire to be hooked up while remote starting to activate certain onboard computers otherwise the vehicle will not start or you will get " SERVICE " light going on or the SECURITY light going on
- Door Trigger - Why is there positive and negative inputs for door triggers - Some vehicles have a neagative trigger door system and other have a positive trigger door system. You have to find what your car has and hook up the appropriate wire to this.
What make, model and year car do you have ? If you can let us know we can post the wire colors that you need to hook up to simplify things for you. ------------- Jeff
Posted By: the12volt
Date Posted: March 26, 2002 at 8:36 AM
Hi m3kgtguy, Starter Output connects to the lead in the ignition harness that only shows 12V+ when the key is in the "START" position. Ignition 1 Output connects to the lead that only shows 12V+ when the key is in the "RUN and START" positions. Ignition 2 Output connects to the lead that only shows 12V+ while the key is in the "RUN" position and usually does not show 12V+ in the accessory and start positions. Accessory Output connects to the lead that only shows 12V+ when the key is in the "ACCESSORY and RUN" positions. Most alarms include a positive and negative door trigger. You didn't mention what type of vehicle you have, but you'll only use one or the other depending on your vehicle. the12volt
Posted By: m3kgtguy
Date Posted: March 26, 2002 at 8:48 AM
Thanks guys... its for a Mitsubishi 3000GT, so if ya've got the wire colors, that would be great... I had one more question about the stater kill circuit... What is the wiring diagram for the relay??? From the alarm, I have a "ground when running / Armed (-) output" -Cody
Posted By: m3kgtguy
Date Posted: March 26, 2002 at 9:11 AM
Also, one more thing... In the main wiring harness, I have Passenger Unlock (-) - this is for the second press of the unlock button for the passenger door But, in a separate, smaller harness, I have these two wires: Green (-) Lock output (500mA) / (+) UNLOCK output (250 mA) Blue (-) Unlock Output (500mA) / (+) LOCK output (250MA) I am guessing that I ned to find what type of locking mechanism I have and use the correct one that pulses the right polarity when the corresponding button is pressed??? -Cody BTW - it's a 1993
Date Posted: March 26, 2002 at 9:26 AM
Hey Cody: Go here for your starter kill interrupt relay : https://www.the12volt.com/info/diagrams.asp#si Go here for the wiring of the alarm / remote starter : https://www.the12volt.com/installbay/detail.asp?info=alarm&year=1991-93&make=Mitsubishi&model=3000GT&ID=18443&type=Alarm The GREEN and BLUE wires for the lock/unlock is all you will need to hook up unless you wish to have separate controls for the driver side door and the passenger side door. ------------- Jeff
Posted By: m3kgtguy
Date Posted: March 27, 2002 at 10:53 PM
Ok, muchos gracias guys.... One more slight little problem... The parking lights don't flash... I went through the setup, and it is set to flash the parking lights... I need to check the wiring again tomorrow, but everything works except this... I am wondering if the wire I found was the wrong one, but according to that page with the color chart, i have the right wire... Will try a jumper wire tomorrow, but if you have any tips, let me know... -Cody
Date Posted: March 28, 2002 at 7:52 AM
Did you test the wire to make sure that the target wire gave you 12 volts when you turned on the lights ? Make sure that it isn't a dimmer wire otherwise you will damage the BCM and this would cost you $$$$. To be sure of the right wire, dim the lights all the way ( the wire should only read about 6 volts ).
------------- Jeff
