Trunk Auto Relock
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=147666
Printed Date: May 05, 2026 at 9:55 AM
Topic: Trunk Auto Relock
Posted By: accordcu2
Subject: Trunk Auto Relock
Date Posted: May 11, 2023 at 6:50 PM
Hi all,
I have an aftermarket smart entry system that has a smart door handle on the front door and also a button on the trunk to open the trunk if the keyfob is in proximity.
However, the system keeps the trunk unlocked when I first unlock and to relock it I have to press the lock button on the keyfob otherwise it will keep it unlocked even key is not in proximity and anyone can come near the car and press the button to open the trunk, sometimes I can forget to press lock on the keyfob, which is annoying and can defeat the purpose of not removing the key out of your pocket or bag.
the solution I can think of is to generate a quick negative 12v pulse when the trunk is closed and send that pulse to the smart entry system module so it can lock everything.
if I use a momentary switch that presses with the trunk, can generate a negative when the trunk is closed but it will keep on generating that negative as it kept pressed.
Is there a relay or anything that can generate a quick pulse when it is de-energized? if I connect that to the trunk light and whenever the power cuts off on the trunk light, it sends a short pulse?
or any other solution?
thanks in advance
------------- Honda Accord
Posted By: i am an idiot
Date Posted: May 14, 2023 at 7:44 PM
I do not know which of these will work for your trunk light. You will have to determine which will work.
https://www.the12volt.com/relays/relaydiagram72.html
https://www.the12volt.com/relays/relaydiagram70.html------------- Let's Go Brandon Brown. Congratulations on your first Xfinity Series Win. LGBFJB
Date Posted: May 15, 2023 at 4:31 AM
Thank you very much, superstar!
