Adding a Door Switch
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=52163
Printed Date: May 14, 2026 at 6:27 PM
Topic: Adding a Door Switch
Posted By: mtxblau
Subject: Adding a Door Switch
Date Posted: March 19, 2005 at 3:16 AM
Hello all,
Thanks to help previously, I successfully installed a CS-2016FM Alarm. Now I want to add a door switch so I can lock the doors without arming the car.
I did a bit of research, but if I'm wrong please let me know.
This the exact wiring diagram I used to wire the door locks.
I believe this is the type of wiring I need to do. I believe I can simply run these negative output wires to the lines coming off the 30's on the alarm's car locking relays, or basically the wires that go too the door lock actuators.
I think this is the type of switch I'd need with the above wiring digram for adding a switch.
If any of this is wrong, please let me know. As far as I can tell, it all looks right, but looks can be deceiving.
Thanks again!
Posted By: auex
Date Posted: March 19, 2005 at 4:20 PM
Ok, go buy a single three position switch or door lock switch(replacement), you can get them at checker or any other autoparts store. Then wire it to pass a ground. Then take one of the outputs and tie it into the blue wire coming off of the alarm and the other to the green wire coming off of the alarm. Autoparts stores have factory looking switches that you can install. Don't make it more difficult than it has to be.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
Posted By: mtxblau
Date Posted: March 19, 2005 at 11:54 PM
Thanks for the response.
So in theory I could just use the stereo ground? The switch will be in the center console, I don't want to wire more than one switch.
The type of switch would be SPDT? An unobtrusive up/down switch is what I'm looking for, since it'll sit right in the middle.
Still, It's bloody freaking brilliant in it's simplicity. Thanks so much!
Posted By: mtxblau
Date Posted: March 22, 2005 at 12:14 AM
Sorry to bump, just wanted to verify that this would be a "momentary SPDT (On-Off-On)". I want to buy toggle switches rather than regular door locks.
