Omega RS-3A Remote Start problems
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=52223
Printed Date: May 15, 2026 at 11:46 AM
Topic: Omega RS-3A Remote Start problems
Posted By: brandonpool21
Subject: Omega RS-3A Remote Start problems
Date Posted: March 20, 2005 at 11:44 AM
Hello, I am looking for some advice on a situation I have involving this starter module.  My girlfriend decided she wanted me to install my Omega starter so I went to get it out of storage and looks like some mice made a nest out of my instructions.  I do not remember how I had this thing wired before and was hoping someone has some info about it.  Also I cannot locate thier website or 800 number.
Let me know what sounds good with this diagram.
Heavy guage harness:
Green = Starter + Output
Yellow = Accessory + Output    (Heater and Acc. I assume)
Red = +12 Volts Input   (inline Fuse 30A)
Red = +12 Volts Input   (Inline Fuse 30A)
Blue = Ignition + Output   (Does this control "Run"?)
Small 3 Pin small guage Adapter:
Aux. Green = Starter#2 - Output
Relay Red = Constant + 12Volts Output
Port Blue = Ignition #2 - Output
Regular Guage Adapter:
Light Blue = Ignition Control (+) Output     (Does this control "Run"?)
Black = Ground
White = Parking lamp Output +
Green = Glow plug + Input
Dark Blue = Hood Safety Switch - input
Yellow/Black = Brake + Input
Pink = Activation - Input
ORANGE / Black = Engine Detect Input   (tach wire I believe)
Orange = Starter Interrupt - Output     (probably a relay interrupt)
The module has the Smart Start and Tach Sensing Switch with LED's as well.  I remember adjusting the knob until the LED was constant for the tach setting, I have no idea what smart start was.
I cannot remember if the RED 12Volt Wires need constant battery on both or just one.
I dont think I even used the 3 pin adapter for #2 start and Ignition
and I am confused by their instructions with Ignition control (+) Output, and the Starter Interrupt.  I didnt use the Interrupt last time I dont think.
I am assuming that the (Ignition control + output) is the activates my computer and "Run" circuits.  But am confused since there is an (Ignition + Output), Which is what?
Does anyone remember if there is a programmable trigger pulse?  There's no jumpers and I dont remember what I did a couple years ago.
If anyone has any info to assist, I would be greatfull, or just the omega website/phone number would work too!
I am on dial up so its proven very difficult and unsuccessful to locate the info.
Thanks for your time.
Posted By: mo12v
Date Posted: March 20, 2005 at 7:13 PM
Omega site is www.caralarm.com  or 1 - 888 - 921-8324 for Tech service.
I have not seen one of those since....................?
Here is PDF.......
rs-3a.pdf
MO
Date Posted: March 21, 2005 at 3:42 AM
That is exactly what I was looking for.  I kinda figured it out later on after the post but still wasnt sure what the "Ignition conrol output" was.... guess its an OEM car alarm disarmer or something....  I never used it.
Nonetheless, I appreciate the quick info on such a prehistoric device.
