remote actuator with momentry relay
Forum Name: Relays
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=125089
Printed Date: May 08, 2026 at 9:10 PM
Topic: remote actuator with momentry relay
Posted By: newbie308
Subject: remote actuator with momentry relay
Date Posted: December 17, 2010 at 7:26 AM
Hi
Firstly Im new to this and my electronic knowledge is very limited
What im trying to do is make an actuator move up and down using a remote using a momantary action
From what I understand I need and actuator (obviously), an ir remote and a power supply
I have sourced a few parts (see below) just dont know how they will or if they can go together
actuator:   https://annbodesign.com/GENERAL-PURPOSE-ACTUATORS-FOR-AUTOMATED-PROJECTS
ir remote: https://#.co.uk/12V-Remote-control-On-off-2-Channel-momentary-relay-/320627757256?pt=LH_DefaultDomain_3&hash=item4aa6e750c8
power supply, i will proberly just use a radio wire
So what i need to happen is that when i hold one of the buttons the actuator opens and when i hold the other button the actuator closes
As i said im not sure how to or if these products will go together, so if not, please could you lead me to another website where i could get the products from, also not sure if i will need limit switches etc etc
ps im in the uk, so a uk based site would be an advantage
thanks pete
Date Posted: December 17, 2010 at 7:31 AM
Date Posted: December 17, 2010 at 7:32 AM
still didnt work, if you go to ebay uk and search for 12V Remote control On/off 2 Channel momentary relay it should come in the search
Posted By: hotwaterwizard
Date Posted: December 20, 2010 at 9:16 PM
https://#.co.uk/12V-12-Volt-Remote-Control-OFF-2-Chan-Bike-Marine-RV-/250616905226?pt=UK_BOI_Lights_Lighting_ET&hash=item3a59ee7e0a#rpdId
This one is better it also latches
Put  c i g . e b a y . c o . u k
John DeRosa (Hotwaterwizard)
Stockton California
When in doubt, try it out !
