2003 bmw 745i need wiring info
stevetolentino
Member - Posts: 38
Posted: August 23, 2009 at 7:14 PM / IP Logged
Someone please help me find info on the wiring for a 2003 BMW 745i, all I really need is info on 12v constant and the starter wire colors.
Thanks in advance.
kola7126
Copper - Posts: 93
Posted: August 26, 2009 at 10:17 AM / IP Logged
BMW MOD. SERIE 7 YEAR 03
POWER SUPPLY +30: connect directly to the big wire coming out of the battery terminal. It is suggested such connection
as some connections with fixed supply are deactivated by the electronic system of the vehicle after about
30 min. from the extinction of the switchboard.
STARTER +50:  2mm2 BLACK wire located in the wiring harness coming out of the MOTRONIC central
placed in the lower part of the antipollen filter, in the engine compartment.
Posted: August 26, 2009 at 11:39 AM / IP Logged
Kola's absolutely right, in fact I would even ignore the ignition RED / green and RED / blue because we've seen some of these time out. Remember what I posted about that on your 6 series request. In fact, all the Germans, I would now suggest fuse box and/or battery.
Monday, April 13, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
