Subwoofer Enclosures
The enclosure is equally as important as the woofer and should be designed for use with the
particular woofer you have chosen.
Deciding which enclosure(s) and woofer(s) are best for you can be a task all of it's own, but size constraints
of the vehicle, knowledge of Thiele - Small parameters, and
understanding the inherent sound characteristics of different enclosure designs will help you decide.
All enclosures should be constructed of at least 5/8'' - 1'' MDF (medium density fiberboard) or material of comparable rigidity or better. Bracing (not shown) should be used throughout the enclosures as needed to prevent any loss of energy due to flexing. For you SPL competitors, I repeat...bracing should be used throughout the enclosures.... Flexing = lost output. With all enclosures, lining the walls with a damping material (fiberglass batting, polyfill, tar based spray, etc.) is recommended to reduce high frequency resonances.
Often the total order of the system is confused with the order of the enclosure. The diagrams shown throughout this section refer only to the order of the enclosure (and are not to scale). The order of the crossover will add to the total order of the system.
There are many types and variations of woofer enclosures. The following information is intended to provide you with a basic understanding of enclosure types and their respective characteristics, design possibilities, and to help you decide which enclosure may work best for you and/or your customers.
| Next - Second Order / Infinite Baffle / Free Air >> |
Subwoofers, Enclosures, & Calculators:
• Second Order / Infinite Baffle / Free Air• Second Order / Acoustic Suspension & Sealed Enclosures
• Fourth Order / Bass Reflex & Bandpass Enclosures
• Sixth & Eighth Order Enclosures
• Parallel & Series Calculators
• Subwoofer Enclosure Calculators
• Subwoofer Wiring Wizard
• Thiele - Small Parameters
Help and Additional Resources:
• Car Audio Forum• Car Audio Home
• Car Audio Hot Topics
• Car Audio Manuals
• Passive Crossovers & Calculators
• Stereo to Bridged Mono Switched Outputs
• Switch Series to Parallel and Back
• Switch Stereo to Bridged Mono & Series to Parallel
Tuesday, August 18, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved • Privacy Policy & Use of Cookies
