06 dodge 2500, remote start
paul h
Copper - Posts: 109
Posted: November 17, 2009 at 10:06 PM / IP Logged
Velocity Motors wrote:
The module you want is the ADS-TBSL C2 and wire up the mulitplex portion of the harness but don't worry about the ignition cylnder part.
OK ya'll....AGAIN I am asking for help!  This thing is driving me nuts!!  I got the module above a few weeks ago and just haven't had time to put it in.  Well I did finally and I can't seem to get it to program.  I got the program set for the vehicle type but thats it.
Will it not enter the other programming stage since I am not using the ignition cylinder part??  Without using or doing this and JUST setting the vehicle type, is the module automatically set for the values for the 2nd accessory and etc?
Reason I ask is it doesn't seem to be activating the accessory upon hitting the start up sequence??
I'm just lost and it's really getting to me....I have NEVER had this much trouble with any vehicle I have done!!!
Thanks to everyone for the help!!
Platinum - Posts: 12,488
Posted: November 18, 2009 at 7:58 AM / IP Logged
If the rmeote start is not capable of controlling the module with D2D through the RS232 wire, you may have to wire it up in standard W2W method. If the module's LED is not turning GREEN when remote started, then the module is not activating hence no start.
paul h
Copper - Posts: 109
Posted: November 18, 2009 at 9:01 PM / IP Logged
That is correct...no green on start or anything.  So wire it direct and see if that makes a difference...will do.  And just to confirm, not using the igntion ring won't have anything to do with it not programming??  Thanks again!!
Posted: November 18, 2009 at 9:16 PM / IP Logged
Correct, with the new firmware, there's no need for the C2 ring for the J1850 immobilizer bypass modules
paul h
Copper - Posts: 109
Posted: November 18, 2009 at 9:20 PM / IP Logged
Thanks Jeff.  I'll give it a try tomorrow.
paul h
Copper - Posts: 109
Posted: November 27, 2009 at 8:36 PM / IP Logged
Well.....an update!  I got it to start finally but I still don't think the module is performing correctly.  When I engage the remote start...the LED on the ADS module starts blinking and thats it.
Also...I set up the ADS for direct wired, but it didn't go to the next step to program the correct vehicle, either 1 or 2 blinks.  I did a master reset and started over and still nothing....
When I engage the RS, the ACC (A/C fan, etc) kicks on for a split second and then off and doesn't come back on until I put the key in.
Is it possible I have a bad module??
Page of 3
