giordon 686 wiring problem
Posted: October 06, 2009 at 5:13 PM / IP Logged
What am I supposed to say, I told you so? Please get yourself an alarm or remote start that's reputable and I'll help you but throw that piece of garbage away.  Why in the name of heaven do you need an actuator?
devilbemmer
Member - Posts: 8
Posted: October 07, 2009 at 4:56 AM / IP Logged
i went to a auto electrics place where i paid for a consultancy fee for the central locking and they advised me to use a actuator , so on there advice spent £30 and installed it as per instructions i was given. so now i have completed that task and also installed the violet wire to my number 1 ht lead , all that is left is the blue wire , which needs to be installed to the negative of the central locking.
so as i have battled on and done much of the install myself i thought a bit of kindness would be nice to finish the job off.
Posted: October 07, 2009 at 2:22 PM / IP Logged
The only kindness is what I've told you already, i.e. junk it.  I've NEVER had to fit an acuator, £7.50 in Maplin by the way to a BMW since the E30 came out in about 1985.  Unless of course one of your factory ones has failed.
devilbemmer
Member - Posts: 8
Posted: October 07, 2009 at 3:26 PM / IP Logged
i have a e36 , i cant believe you are so negative everything works on the alarm even the remote start, the oscillator has a small cliche and i know it is to do with the blue wire that has to go to the central locking door negative, i thought you would at least solve this last problem just to get rid of me, and by the way the alarm aint that doodie if it works. at least you will save me from going back to the auto electrics shop
Posted: October 08, 2009 at 1:02 AM / IP Logged
What do you mean by central locking door negative. the locks on that model are pos triggered. That car takes me 4 hours to do an alarm /rs.  I gave you FULL instructions earlier on, you could even have had photos if you'd have pm'd me so don't tell me I'm being negative. I do this for a living and I know the product.  What do you mean by oscilator?  Siren?
boxhead78
Copper - Posts: 84
Posted: October 08, 2009 at 10:02 PM / IP Logged
go to www.12volt.com and get your wiring diagram but you may have to use relays for the door locks
boxead78
Posted: October 09, 2009 at 2:27 AM / IP Logged
The only reason for relays on that car would be to flip the neg lock outputs of an alarm that didn't have pos locking, or for total close and deadlocking with a diode to each lock wire.
Friday, April 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
