dei 515r w/507m , 506t
kophinos
Posted: August 24, 2009 at 11:37 PM / IP Logged
I have a Python 991 w/glass break sensor (506T) installed in my vehicle and I have a battery backup siren (515R) and a tilt sensor I'd like to add on to the unit. From my research I've learned I would connect everything as follows:
Siren 515R
Red -> (+)12v
Black -> Ground
Violet -> (+)trigger (brown #3 on H1 harness of the 991)
Tilt Sensor 507M
Red -> (+)12v
Orange -> (-)Ground when armed (also orange on, wire #12 on the H1 harness of the 991)
Blue -> instant trigger ((-) trunk pin/instant trigger, #7 on the H1 harness of the 991)
Does this all look correct so far? I shouldn't have any problem splicing multiple sirens to the single brown (H1/3) of the 991 would I? Would I need to add a diode on the blue instant trigger for the 507 tilt sensor?
t&t tech
Platinum - Posts: 2,622
Posted: August 25, 2009 at 8:52 PM / IP Logged
Yes it looks correct! You may not have problems with multiple sirens right away but it would be advisable to run a relay of that siren wire, as the alarm really only is made to accomadate one! If there is currently a trigger input on that blue trigger wire you would need to diode these inputs, band facing away from alarm.
kophinos
Posted: August 25, 2009 at 10:29 PM / IP Logged
i went ahead and wired it as i said tonight without a diode on the instant trigger, however when the tilt triggers the remote pages "trunk open" which is to be expected because i have both the trunk trigger and the tilt on the same blue wire to the alarm CPU. could relocate the blue from the instant trigger of the H1 harness of the alarm and tap it into the blue of the glassbreak, so it will instantly trigger the alarm, but not page as "trunk open"?
kophinos
Posted: August 25, 2009 at 10:31 PM / IP Logged
also, i assume the diode i would need to use is the 1N4001 1amp diode, correct?
jasonlipka
Member - Posts: 49
Posted: August 26, 2009 at 2:53 PM / IP Logged
Yes, you can do that. The problem is as you said it is - you have the trunk pin and tilt trigger on the same input. Thus, when the brain receives a ground input on that terminal, whether it be from the tilt switch or the trunk pin, it is interpreting this as "trunk is open".
Either way you described will trigger the alarm, but using the instant trigger on the aux sensor port (where you currently have your glass break sensor hooked) won't signal the brain that the trunk is open.
Also, if you splice it into the glass break wire, there is no need to use a diode.
Monday, April 13, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
