auto start alarm for mazda rx8
vbezzina
Posted: September 20, 2009 at 10:56 PM / IP Logged
Hi ive fitted a SPY 5000m to a 2003 mazda rx8 but cant get it to auto start. There is one wire which i believe needs to be hooked up for this to work but i dont know where it goes. The wire is the "start sensing wire"
If anyone can help it would be much appreciated.
Thank you
tommy...
Gold - Posts: 1,901
Posted: September 20, 2009 at 11:17 PM / IP Logged
When you attempt to remote start...what does it do...? Also...is there a link tot he install manual...?
M.E.C.P & First-Class
tommy...
Gold - Posts: 1,901
Posted: September 20, 2009 at 11:45 PM / IP Logged
When it cranks...Does it seem like its not long enough to start the car? Try adjusting crank time...You cant post the manual here...?
vbezzina
Posted: September 20, 2009 at 11:49 PM / IP Logged
i dont know how to post the manual. Im new sorry
vbezzina
Posted: September 21, 2009 at 12:44 AM / IP Logged
hey just wondering if anyone might be able to tell me where the tach wire is on a automatic 2003 mazda rx8
thanks
tommy...
Gold - Posts: 1,901
Posted: September 21, 2009 at 1:16 AM / IP Logged
This is for an 04...Not sure if it the same...?
BatteryYELLOW(+)IGNITION SWITCH HARNESS
auto start alarm for mazda rx8 -- posted image.Ignition 1BLACK / YELLOW(+)IGNITION SWITCH HARNESS
auto start alarm for mazda rx8 -- posted image.Accessory 1BLUE/GREEN(+)IGNITION SWITCH HARNESS
auto start alarm for mazda rx8 -- posted image.Accessory 2WHITE/ RED(+)IGNITION SWITCH HARNESS
auto start alarm for mazda rx8 -- posted image.Starter 1WHITE/ BLUE(+)IGNITION SWITCH HARNESS
auto start alarm for mazda rx8 -- posted image.Anti-Theft TypeTRANSPONDER
auto start alarm for mazda rx8 -- posted image.Anti-Theft DescriptTHE KEY SENDS AN RF SIGNAL TO THE BCM MODULE THROUGH AN ANTENNA LOCATED AROUND THE IGNITION CYLINDER
auto start alarm for mazda rx8 -- posted image.Key SensePINK/BLACK(-)IGNITION SWITCH HARNESS
auto start alarm for mazda rx8 -- posted image.TachometerLIGHT GREEN/ RED(AC)AT PCM MODULE UNDER BATTERY COVER
auto start alarm for mazda rx8 -- posted image.Speed SenseGREEN/ RED(AC)AT ABS CONTROL MODULE BEHIND LEFT HEADLIGHT
auto start alarm for mazda rx8 -- posted image.Parking LightsBLACK/ RED(+)DRIVERS KICK PANEL
auto start alarm for mazda rx8 -- posted image.Brake LightsBLACK/ BLUE(+)AT THE BRAKE PEDAL SWITCH
auto start alarm for mazda rx8 -- posted image.Reverse LightsRED / YELLOW(+)IN HARNESS IN DRIVER KICKPANEL TO REAR
auto start alarm for mazda rx8 -- posted image.HornGREEN/ ORANGE(-)IN HARNESS AT STEERING COLUMN
Thack79
Silver - Posts: 526
Posted: September 21, 2009 at 7:35 AM / IP Logged
didnt know they made an rx8 in 2003.
t&t tech
Platinum - Posts: 2,622
Posted: September 21, 2009 at 10:52 AM / IP Logged
I think that would be new to all the members here! LOL auto start alarm for mazda rx8 -- posted image.
vbezzina
Posted: September 21, 2009 at 10:09 PM / IP Logged
Thanks guys for your help much appreciated
Another thing what is the PCM module?
tommy...
Gold - Posts: 1,901
Posted: September 22, 2009 at 5:09 AM / IP Logged
PCM... http://www.aa1car.com/library/pcm.htm
Function
  • Step 1:
    A powertrain control module is a printed circuit board computer housed in a heavy duty case that can withstand the extremes of temperatures normally experienced inside a vehicle's engine. The module constantly sends electronic signals to all of the different components in the engine, and tests the temperature and airflow around them, to check on the status of their operation. When a component is not working properly, the module turns on the "check engine light" on your vehicle's dashboard.
Features
  • Step 1:
    The control module examines the camshaft, coolant levels, crankshaft, ignition and valve timing, air intake and the turbocharger components in a car. It automatically regulates the ratio of air to fuel used in the engine and controls the idle speed so that the vehicle operates at peak performance levels. The module also works in conjunction with the catalytic converter to reduce the amount of pollutants expelled with the engine's exhaust and maintains the speed of the vehicle when the "cruise control" feature is turned on.
Benefits
  • Step 1:
    All powertrain control modules generate a specific diagnostic code based on the vehicle component that isn't working that can then be read by an electronic diagnostic tool used by mechanics. Reading the code makes diagnosing a vehicle's problem much easier than trial and error replacement of parts. As an extra benefit some modules can be re-programmed when new components are added to maximize efficiency or give performance increases.
Types
  • Step 1:
    Different makes and models of cars produced in different years may have separate kinds of connectors to plug into a diagnostic reading tool, although the connectors are almost always found in the same spot below the dashboard on the driver's side. Each model of powertrain control module will also have a different amount of memory to store previous diagnostic codes before old ones are erased to make room for new ones.
Considerations
  • Step 1:
    In cold temperatures, the powertrain control module executes a predetermined set of basic instructions until the engine raises to its normal temperature range, at which point the module then switches back to normal operation. The module also cannot work when the battery is disconnected and all codes will be deleted from its memory if the battery remains disconnected for more than 10 minutes. A module does not have a code to indicate when it is experiencing a problem, so the best indicator of a module failure is if it begins to produce codes for components that aren't malfunctioning.
