2006 suzuki grand vitara
v0lume04
Posted: September 24, 2009 at 5:07 PM / IP Logged
i am looking for remote start wiring info for a 2006 suzuki grand vitara thanks -Tony
chev104275
Gold - Posts: 1,436
Posted: September 24, 2009 at 5:16 PM / IP Logged
Remote Start
WIRE COLOR POLARITY LOCATION
Battery WHITE/ RED
Ignition 1 BLACK / YELLOW
   THE STARTER WIRE IS ALSO BLACK / YELLOW, BE SURE TO TEST THESE WIRES
Accessory 1 YELLOW
Accessory 2 BLUE (+) IGNITION SWITCH HARNESS
Starter 1
   THE IGNITION WIRE IS ALSO BLACK / YELLOW, BE SURE TO TEST THESE WIRES
Anti-Theft Type UNIVERSAL IMMOBILIZER
Anti-Theft Descript THE KEY SENDS AN RF SIGNAL TO THE BCM MODULE THROUGH AN ANTENNA LOCATED AROUND THE IGNITION CYLINDER
Key Sense BLUE/RED (+) IGNITION SWITCH HARNESS
Tachometer PINK (AC) AT FUEL INJECTOR #1
   ALSO AT ECM MODULE UNDER HOOD
Speed Sense BLUE/BLACK (AC) AT ABS CONTROL MODULE UNDER HOOD TOWARDS FRONT CENTER OF COMPARTMENT
Low Crr. Pk Lights RED / BLUE (-) AT VEHICLE HEADLIGHT SWITCH
Brake Lights GREEN / WHITE (+) AT SWITCH ABOVE BRAKE PEDAL
Reverse Lights RED (+) IN HARNESS IN DRIVER KICKPANEL TO REAR
Horn BLUE (-) AT BCMMODULE IN DRIVER KICKPANEL
POWER LOCK PINK/BLACK (TYPE B)   IN DRIVERS KICK PANEL or BCM, 40-Pin Plug, Pin 27, See NOTE *1
POWER UNLOCK PINK/GREEN (TYPE B)   IN DRIVERS KICK PANEL or BCM, 40-Pin Plug, Pin 26, See NOTE *1
check the door lock wires i dont have my diagram with me im at home right now    ive never used that site for wiring      if you dont have it already ill get it tommorrow for you
v0lume04
Posted: September 26, 2009 at 11:46 AM / IP Logged
anyone able to post from dei's site?
Posted: September 26, 2009 at 12:41 PM / IP Logged
The 07 Grand Vitara is on this site in the vehicle wiring section. If the body is the same the wiring SHOULD be but use it as a basis for your install.
