radio on till open door
Thack79
Silver - Posts: 526
Posted: September 29, 2009 at 7:51 AM / IP Logged
how do you eliminate the radio playing until the door opens in a Ford,Lincoln, Mercury. When noted for a door trigger most places ask for a domelight which i cant use. I dont see a door trigger in the door the i can use like most foreign cars. What can i do????
In particular im working with a 2004 mercury mountaineer, 2002 lincoln continental, and a 1999 lincoln town car
KPierson
Platinum - Posts: 3,527
Posted: September 29, 2009 at 11:06 AM / IP Logged
A lot of Fords use a + (or -) door switch that is integrated in to the striker plate in the door itself (as opposed to a pin switch in the jamb).
There should still be a signal, you may just have to find it the hard way.
Sorry for not being able to provide specific info, but maybe this will help you a bit.
Kevin Pierson
racerjames76
Silver - Posts: 581
Posted: September 29, 2009 at 11:10 AM / IP Logged
02 Continental
LF LatchDRK/BLUE(-)IN DRIVERS DOOR
RF LatchBLACK/ ORANGE(-)PIN 9 OF 22 PIN CONN. @ LCM
LR LatchBLACK/ ORANGE(-)PIN 9 OF 22 PIN CONN. @ LCM
RR LatchBLACK/ ORANGE(-)PIN 9 OF 22 PIN CONN. @ LCM
99 town car
LF LatchBLUE(-)AT MODULE IN DRIVERS DOOR
RF LatchBLACK/ ORANGE(-)IN HARNESS AT VEHICLE LIGHT SWITCH
To master and control electricity is perfection. *evil laugh*
Thack79
Silver - Posts: 526
Posted: September 29, 2009 at 12:02 PM / IP Logged
can i ground any pin or does it have to be the drivers door???
KarTuneMan
Platinum - Posts: 7,056
Posted: September 30, 2009 at 11:33 PM / IP Logged
Test it.... sit in the pass side and shut the key off and open the door... I'll bet it works!
Thack79
Silver - Posts: 526
Posted: October 01, 2009 at 7:59 AM / IP Logged
ill check it out this weekend. Any one have the 04 mountaineer door pin wires??
tommy...
Gold - Posts: 1,901
Posted: October 01, 2009 at 8:26 AM / IP Logged
All Door TriggerBLACK/ BLUE(+)AT DRIVER'S DOOR SILL PLATE HARNESS
radio on till open door -- posted image.Domelight SuperBLACK/ BLUE(+)AT DRIVER'S DOOR SILL PLATE HARNESS
radio on till open door -- posted image.LF LatchYELLOW/BLACK(+)AT CSM MODULE...PIN #1radio on till open door -- posted image.
radio on till open door -- posted image.RF LatchGRAY/RED(+)AT CSM MODULE...PIN #2radio on till open door -- posted image.
radio on till open door -- posted image.LR LatchLIGHT GREEN/ YELLOW(+)AT CSM MODULE...PIN #9radio on till open door -- posted image.
radio on till open door -- posted image.RR LatchPINK/LIGHT BLUE(+)AT CSM MODULE...PIN #7radio on till open door -- posted image.
Module 1PCM - ON PASSENGER SIDE OF FIREWALLradio on till open door -- posted image.
radio on till open door -- posted image.Module 2ABCM - BEHIND DRIVERS SIDE HEADLIGHT
radio on till open door -- posted image.Module 3CSM - BEHIND TRIM NEAR RIGHT REAR SEAT
M.E.C.P & First-Class
Thack79
Silver - Posts: 526
Posted: October 01, 2009 at 8:46 AM / IP Logged
perfect thanks tommy.
and Kartuneman yeah it does work. Was trying my best not to go into the door. lol
Tuesday, April 14, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
