2004 350z manual, vper 5901
tw8715
Posted: August 27, 2009 at 5:02 AM / IP Logged
Hello all! got a 04 350z MANUAL.
went to my local shop today and got the viper 5901 installed w/ remote start on the manual.
WORKS great! except............................................... lol
there is a STOCK alarm led indecator light. it usually blinks when the alarm was enabled on the stock alamr.
now after installing the viper it works the same. BUT when i remote start the car.. turn the key to the right possition.. and step on the brake pedal.. the stock led indecator light stays SOLID... only on remote start.. after pressin brake pedal.
very annoying at night. whats up? my installer dosnt know why? maybe you guys could chime in and help me out so i could tell him wassup! lol
ALSO.. after stepping on the brakes.. the interior cabin lights turn on for a brief time and then off. any way so they dont turn on at all after stpeeing on the brake pedal?
i think my installer was bad............  i also wanted a feture where my windows could be rolled up. i heard with the viper 5901 i got.. when i lock my car.. the windows would roll up automatically? was kinda looking forward to this feature.
PLEASE HELP!
tw8715
Posted: August 27, 2009 at 5:03 AM / IP Logged
2004 NISSAN 350Z
MANUAL TRANSMISSION
VIPER 5901 W/ remote start
KPierson
Platinum - Posts: 3,527
Posted: August 27, 2009 at 10:31 AM / IP Logged
To get the windows to roll up you have to extend (-) trigger on the acutal lock wire INSIDE the door.  If the installer didn't run a lock wire inside the door then you can not add this feature.
For the security LED, what kind of bypass did he use?
Kevin Pierson
tw8715
Posted: August 27, 2009 at 1:13 PM / IP Logged
no idea~~~~~~~~~~~~~ wat bypass is he suppose to use?
thanks
number2
Copper - Posts: 73
Posted: August 27, 2009 at 5:36 PM / IP Logged
I have some weird issues with my wifes altima also I installed a 712t. Like it won't arm the factory alarm unless a door is open when you lock the doors with the remote. The domelight supervision will only work if you have shut the door within 2 minutes. Push the panic button and the dome light flashes too. The factory disarm wire works and turns off the security light everytime though.
tommy...
Gold - Posts: 1,901
Posted: August 30, 2009 at 5:14 PM / IP Logged
thanks
There are a few different bypasses he could have used...The model # would narrow down the options of what is wrong...The model # is not listed on the receipt...? on some vehicles you have to cut and incorporate the securty L.E.D  w/ the bypass...!
M.E.C.P & First-Class
tommy...
Gold - Posts: 1,901
Posted: August 30, 2009 at 5:16 PM / IP Logged
Oh and BTW...Just because the unit can do something does not mean that it is included in the price...We sell alarms w/o keyless all the time...Unless he charged you for that feature...Why would he include it...Did you specifically ask for that feature...An additional labor charge would be added for sure...!
tw8715
Posted: October 09, 2009 at 12:15 PM / IP Logged
so horror storry here ... for me at least.
2004 nissan 350z manual.
viper 5901 w/remote start.
local shop installed and works great! except the doors dont lock half the time! but the alarm engages all the time. just the doors dont seem to lock sometimes.
they said they installed it with a modual and they program my car into it.
any pointers why its doing this? help plz! also it kinda lags when i press the lock on the remote. the remote itself dosnt lag.. but takes the car a couple seconds sometimes for the alarm to engage.
thanks!
Platinum - Posts: 13,726
Posted: October 09, 2009 at 12:28 PM / IP Logged
The door lock wires are only accessible in the drivers door. I have no idea what kind of module they used, but they should be able to connect the door locks the old fashioned way.
2004 350z manual, vper 5901 -- posted image.Power UnlockLIGHT BLUE(-)AT THE SWITCH IN THE DRIVER'S DOOR DBL PULSE2004 350z manual, vper 5901 -- posted image.
2004 350z manual, vper 5901 -- posted image.PowerLockRED(-)AT THE SWITCH IN THE DRIVER'S DOOR
KPierson
Posted: October 09, 2009 at 12:46 PM / IP Logged
Have them replace the module that they installed and see if that fixes the problem.  While they are replacing the module have them make sure they soldered all their wires.
I'm with I am an idiot, have them hardwire the door locks.  While they are in there, have them enable the comfort closing feature of the system.  Once done, not only will you have door locks that work but you'll also have windows that open and close with the remote.
I believe the 5901 is a two way system.  DEI 2 way systems tend to lag.  You'll get used to it.  I know I almost have.
Hmm... it seems like I've typed all of this already!
Kevin Pierson
Saturday, April 11, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
