Subwoofer Wiring Wizard, Four 2 Ohm Dual Voice Coil (DVC) Speakers
Below are the available wiring diagrams for the speaker configuration you selected. The resulting impedance (ohm load) is considered the "Nominal Impedance" seen by the amplifier.
Note: One or all of the wiring options shown in this application may not be compatible with your amplifier because of low impedance loads. Please check your amplifier owner's manual to determine the best wiring option and verify the overall impedance load is compatible with your amplifier before making any connections. When making any connections, observe proper polarity to prevent damage to your amplifier and/or speaker system. *The location of positive (+) and negative (-) speaker terminals have been reversed in one or more diagrams for easier readability.
Four 2 Ohm Dual Voice Coil (DVC) Speakers Wiring Diagrams
| << Previous - Subwoofer Enclosure Calculators | Next - Subwoofer Enclosures Home >> |
Subwoofers, Enclosures, & Calculators:
• Second Order / Infinite Baffle / Free Air• Second Order / Acoustic Suspension & Sealed Enclosures
• Fourth Order / Bass Reflex & Bandpass Enclosures
• Sixth & Eighth Order Enclosures
• Parallel & Series Calculators
• Subwoofer Enclosure Calculators
• Subwoofer Wiring Wizard
• Thiele - Small Parameters
Help and Additional Resources:
• Car Audio Forum• Car Audio Home
• Car Audio Hot Topics
• Car Audio Manuals
• Passive Crossovers & Calculators
• Stereo to Bridged Mono Switched Outputs
• Switch Series to Parallel and Back
• Switch Stereo to Bridged Mono & Series to Parallel
Sunday, May 3, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved • Privacy Policy & Use of Cookies
