car audiowoofercalculator
Subwoofer Wiring Wizard, One 4 Ohm Single Voice Coil (SVC) Speaker
Select quantity and impedance.
Speaker Qty.
Voice Coil Impedance
Additional combinations and values may be calculated with our Parallel and Series Calculators. If you do not find the information you're looking for, please post your request at the12volt's Install Bay - Mobile Electronics Forums. We will NOT respond to any requests by e-mail.
Below are the available wiring diagrams for the speaker configuration you selected. The resulting impedance (ohm load) is considered the "Nominal Impedance" seen by the amplifier.
Note: One or all of the wiring options shown in this application may not be compatible with your amplifier because of low impedance loads. Please check your amplifier owner's manual to determine the best wiring option and verify the overall impedance load is compatible with your amplifier before making any connections. When making any connections, observe proper polarity to prevent damage to your amplifier and/or speaker system. *The location of positive (+) and negative (-) speaker terminals have been reversed in one or more diagrams for easier readability.
Your ad blocker is preventing this page from displaying correctly.
One 4 Ohm Single Voice Coil (SVC) Speaker Wiring Diagram
top of page One 4 Ohm Single Voice Coil (SVC) Speaker
Option 1 = 4 ohm load
Recommended Amplifier: Stable at 4, 2, or 1 ohm mono
One 4 Ohm SVC Speaker = 4 ohm load
1 Ohm Dual Voice Coil:
One 1 Ohm DVC
Two 1 Ohm DVC
Three 1 Ohm DVC
Four 1 Ohm DVC
2 Ohm Dual Voice Coil:
One 2 Ohm DVC
Two 2 Ohm DVC
Three 2 Ohm DVC
Four 2 Ohm DVC
4 Ohm Dual Voice Coil:
One 4 Ohm DVC
Two 4 Ohm DVC
Three 4 Ohm DVC
Four 4 Ohm DVC
6 Ohm Dual Voice Coil:
One 6 Ohm DVC
Two 6 Ohm DVC
Three 6 Ohm DVC
Four 6 Ohm DVC
4 Ohm Single Voice Coil:
One 4 Ohm SVC
Two 4 Ohm SVC
Three 4 Ohm SVC
Four 4 Ohm SVC
8 Ohm Single Voice Coil:
One 8 Ohm SVC
Two 8 Ohm SVC
Three 8 Ohm SVC
Four 8 Ohm SVC
<< Previous - Subwoofer Enclosure Calculators Next - Subwoofer Enclosures Home >>
Subwoofers, Enclosures, & Calculators:
Second Order / Infinite Baffle / Free Air
Second Order / Acoustic Suspension & Sealed Enclosures
Fourth Order / Bass Reflex & Bandpass Enclosures
Sixth & Eighth Order Enclosures
Parallel & Series Calculators
Thiele - Small Parameters
Help and Additional Resources:
Car Audio Forum
Car Audio Home
Car Audio Hot Topics
Car Audio Manuals
Passive Crossovers & Calculators
Stereo to Bridged Mono Switched Outputs
Switch Series to Parallel and Back
Switch Stereo to Bridged Mono & Series to Parallel
Monday, May 18, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
