the12volt.com - Free Technical Information for Mobile Electronics Installers since 1999
the12volt.com - Free Technical Information for Mobile Electronics Installers, Enthusiasts, and Do-It-Yourselfers since 1999 Ohm's Law - It Rules!
BasicsCar AudioCar SecurityCruise ControlsDiodesDoor LocksOhm's LawPassive CrossoversRelaysResistorsSubwoofer Enclosures Search
Application GuidesCalculators, Charts, DiagramsDownloadsFind InstallersForumsGlossarySubwoofer WiringToolsVehicle Wiring Active Forum Topics
Diodes
Ohm's Law
Relays
Resistors
Tools and Equipment
Glossary of Terms
Introduction
Metra Application Guides
Parallel & Series Calcs
Passive Crossovers
Port Length Calculators
Power & Ground Wire Sizes
Subwoofer Box Calculators
Subwoofer Enclosure Types
Subwoofer Wiring Options
Thiele - Small Parameters
Miscellaneous
The Application Guide
Vehicle Wiring Database
Introduction
Alarm Accessories
Alarm Modules
Alarm Sensors
Basic Connections
Illuminated Entry
Light Flash
Power Door Locks
Starter Interrupts
Insurance
Introduction
Electrical Connections
Mechanical Connections
Servo Settings
VSS and Tach Info
Vehicle Wiring Databse
All Forums
Buy & Sell Equipment
Car Audio
Car Security & Convenience
Cellular & Communications
Cruise Controls
Employment
Fiberglass & Fabrication
Forum Help & How To
General Discussion
Lights, Neon, LEDs, HIDs
Miscellaneous
Mobile Video & Navigation
Motorcycle Electronics
Music, Favorite Songs
Forum & Site Notices
Relays
Rides & Systems Gallery
Vehicle Information
Last 100 Forum Topics
Books & DVDs
Calculators
Charts
Diagrams
Downloads
Find an Installer
Forums - Q&A
Glossary of Terms
Insurance
Links
Mobile Tech News
About the12volt
Hurricane Katrina
Link to Us
Support Us
Car Alarms
Keyless Entry
Remote Car Starters
Power Windows
Power Door Locks
Shaved Door Handles
Headlights
Tail Lights
Body Kits
Tail Lights
Headlights
Intakes
Rims
Headers
Civic Exhaust
Mustang Exhaust
Headlights
Tail Lights
Fog Lights
Mirrors
Cooling Fan Assembly
Body Kits
TopGearAutosport.com
Subwoofer Wiring Wizard, Two 2 ohm Dual Voice Coil (DVC) Speakers
Subwoofer Wiring Wizard Speaker Qty. Voice Coil Impedance
Select quantity and impedance.
Additional combinations and values may be calculated with our Parallel and Series Calculators. If you do not find the information you're looking for, please post your request at the12volt's install bay - Mobile Electronics Forums. We will NOT respond to any requests by e-mail.
Below are the available wiring diagrams for the speaker configuration you selected. The resulting impedance (ohm load) is considered the "Nominal Impedance" seen by the amplifier.
Note: One or all of the wiring options shown in this application may not be compatible with your amplifier because of low impedance loads. Please check your amplifier owner's manual to determine the best wiring option and verify the overall impedance load is compatible with your amplifier before making any connections. When making any connections, observe proper polarity to prevent damage to your amplifier and/or speaker system. *The positive (+) and negative (-) speaker terminals have been reversed in one or more diagrams for easier readability.
top of page Two 2 ohm Dual Voice Coil (DVC) Speakers
Option 1 (parallel/parallel) = 0.5 ohm load
Voice coils wired in parallel, speakers wired in parallel
Recommended Amplifier: Stable at 1/2 ohm mono
Two 2 ohm DVC Speakers = 0.5 ohm load
Option 2 (series/parallel) = 2 ohm load
Voice coils wired in series, speakers wired in parallel
Recommended Amplifier: Stable at 2 or 1 ohm mono
Two 2 ohm DVC Speakers = 2 ohm load
Option 3 (series) = 8 ohm load
All voice coils wired in series
Recommended Amplifier: Stable at 4, 2, or 1 ohm mono
Two 2 ohm DVC Speakers = 8 ohm load
Car Audio:
Glossary
Ohm's Law
Passive Crossovers & Calculators
Power and Ground Cable Sizes
Subwoofer Enclosures & Calculators
Subwoofer Wiring
the12volt's Application Guide
the12volt's Install Bay (forums)
Tools & Equipment
Passive Crossovers:
Low Pass Filters
High Pass Filters
Band Pass Filters
Narrow Band Pass Filters
Acoustical Output & Power
First Order Filters
Second Order Filters
Third Order Filters
Zobel
2 Ohm Charts
4 Ohm Charts
8 Ohm Charts
Formulas & Calculators
Car Audio Hot Topics:
 Running one vc on a dvc sub
 How to choose an amplifier.
 Favorite car audio brand, updated
 Ground Q/A sticky
 How to Set Your Gains
 What is a proper sub box?
 Guide: Using WinISD
 Comprehensive front stage setup
 Too Little Power
 How to wire through a door molex.
 How to choose a car CD receiver.
 How to upgrade the Big Three
 Fuse size?
 Ohms, using resistors with woofers?
 Advanced front speaker systems how-to
 How to identify stereo wiring.
 What is a proper ground?
Subwoofer Enclosures:
Calculators: Parallel, Series, Port Length, & Volume
Second Order / Infinite Baffle / Free Air
Second Order / Acoustic Suspension / Sealed
Fourth Order / Bass Reflex & Bandpass Enclosures
Sixth & Eighth Order / Bandpass Enclosures
Subwoofer Wiring Configurations
Featured Forum Topics:
 Breaking in subs
 Headrest Monitor How-To
 Ground Q/A Sticky
 Guide: Using WinISD
 Loudspeaker sensitivity vs efficiency
 Too little power
 Voice Coil Wiring and Transient Response
Mobile Video & Navigation:
 Video In Motion Law
 Headrest how-to, 06 Chrysler 300c
 Headrest Monitor How To, 91 Accord
Fiberglass, Fabrication & Interiors:
 Tinting Clear Plastic
 How to Make a Fiberglass Enclosure
 Flushing a remote, fun little project
 Fiberglass, Roush Mustang
 Fiberglass shopping list
 How to make circular rings
 Sticky Packing peanut volume measurement
Car Audio Wiring and Relay Diagrams:
American Wire Gauge Sizes
Connecting Additional Devices to Remote Turn Lead
Radio On Until Door Opened
Stereo to Bridged Mono Switched Outputs
Subwoofer Wiring Wizard for SVC and DVC Speakers
Switching from Series to Parallel and Back
Switching from Stereo to Bridged Mono & Series to Parallel
Typical Head Unit Wire Harness
ohm's law, resistors, relays, and more
Google
Wednesday, March 10, 2010 Copyright © 1999-2010 the12volt.com Donate to the12volt.com Privacy Policy Advertising
the12volt.com - Free Technical Information for Mobile Electronics Installers, Enthusiasts, and Do-It-Yourselfers since 1999 Donate to the12volt.com
