Tweeter location
jaime zeledon
Member - Posts: 24
Posted: January 18, 2007 at 7:02 PM / IP Logged
My question is where is the best place to mount tweeters. There isnt any room in the doors so i was thinking of putting them on the headliner next to the visors is this an ok place?
kirktcashalini
Silver - Posts: 492
Posted: January 18, 2007 at 7:15 PM / IP Logged
I believe the best location to locate tweeters is relatively close to the mid drivers, as it will be out of phase when the sound gets to your ears if they are in a far different location
the12volt
Administrator - Posts: 3,959
Posted: January 18, 2007 at 7:49 PM / IP Logged
Rule of thumb is to place the tweeters as close to the mids as possible not because of any potential phase issues as kirktcashalini suggested, but because the frequencies reproduced by both the midrange and tweeter are directional. They should work together to create a seamless point of origin rather than two or more points of origin for the same source such as vocals, guitars, saxophones, etc. Woofers can be succesfully placed further away from the midrange and tweeter group because the frequencies they typically reproduce (<100 Hz) are non-directional.
jaime zeledonm, mounting your tweeters in the headliner or near your visors would be a very bad idea.
Tweeter location -- posted image. the12volt • Support the12volt.com
DYohn
Platinum - Posts: 10,741
Posted: January 19, 2007 at 12:12 PM / IP Logged
Indeed.  That's perhaps the worst location I can imagine.  Keep them within one woofer diameter of the mid if you can.
killer sonata
Silver - Posts: 718
Posted: January 19, 2007 at 7:39 PM / IP Logged
This question cannot be answered correctly because it is way too general. Tweeter mounting in every type of vehicle is very different. To find the best location for YOUR vehicle, you will have to test all of your possibilites to find your favorite.
jaime zeledon
Member - Posts: 24
Posted: January 19, 2007 at 9:00 PM / IP Logged
Thanks for the advice il try diffrent positions for the best sound.
haemphyst
Platinum - Posts: 5,059
Posted: January 19, 2007 at 10:10 PM / IP Logged
...while still keeping all of the above suggestions and recommendations in mind.
coppellstereo
Silver - Posts: 785
Posted: January 19, 2007 at 10:11 PM / IP Logged
in SQ setups you try to move the sound stage as far forward and as wide as possible (perceptively).
Q forms are always a good thought
