2004 Kia optima alarm/remote start
Welcome Guest :)
MikeHusain
Copper -
Posted: November 19, 2004 at 11:46 AM / IP Logged
I was wondering if anyone had wire schematics for alarm/remote start for 04 KIA OPTIMA? Thanks....
snguyen
Silver -
Posted: November 19, 2004 at 12:03 PM / IP Logged
Remote Starter Wiring Colors and Notes |
Function | | Vehicle Color | Location |
Start: | | Yellow (+) | Ignition switch harness |
Ignition #1: | | Pink (+) | Ignition switch harness |
Ignition #2: | | N/A | Ignition switch harness |
Ignition #3: | | N/A | Ignition switch harness |
Accessory: | | Orange (+) | Ignition switch harness |
Brake Light: | | Green(+) | Brake pedal switch |
Tach Signal: | | White (AC) | Instrument cluster or ECM* |
Parking Lights: | | Pink or BROWN / Orange (+) | Fuse box |
Headlights: | | N/A | |
OEM Alarm Disarm: | | Factory remote only | |
OEM Alarm Arm: | | Factory remote only | |
Diesel Glow Plug: | | N/A | |
Clutch Bypass Wire: | | N/A | |
Notes: | | *The Engine Control Module (ECM) is behind the lower center of the dash. On the 2.4L can also use white or orange at the ignition coils. On the 2.5L can also use yellow, white, or black at the ignition coils. |
Alarm and Keyless Entry Wiring Colors and Notes |
Constant +12 Volts: | | Red (x2) | Ignition switch harness |
Starter Kill: | | Yellow (+) | Ignition switch harness |
Ignition +12 Volts: | | Pink (+) | Ignition switch harness |
Dome Lights/Superv: | | Yellow (-) | Drivers kick panel or ETACS** |
OEM Horn: | | Yellow (-) | Steering column harness |
Power Lock: | | White (-) | Back of the fuse box or ETACS** |
Power Unlock: | | Blue (-) | Back of the fuse box or ETACS** |
Trunk Release: | | Blue (+) | Drivers kick panel harness to the rear |
Alarm Input Wire: | | Yellow (-) | Drivers kick panel or ETACS** |
Notes: | | **The Electronic Time and Alarm Control System (ETACS) module is attached to the underdash fuse box. See Note #201 Negative Trigger Door Locks |
MikeHusain
Copper -
Posted: December 01, 2004 at 7:02 PM / IP Logged
Friday, April 26, 2024
• Copyright © 1999-2024 the12volt.com, All Rights Reserved
• Privacy Policy & Use of Cookies
