2008 saturn vue audiovox aps620 bypass?
mbaudio06
Copper - Posts: 60
Posted: December 14, 2007 at 11:28 AM / IP Logged
2008 Saturn Vue
AUdiovox APS620
Which bypass module would i use for this particular vehicle. Also i cant seem to find a wiring diagram for it most of the sites only go up to 06?
perly
Copper - Posts: 155
Posted: December 14, 2007 at 12:36 PM / IP Logged
I have been using idatalink for a bit now and I like how they work. THey also make life alot easier when it comes to anything multi-plex. CLick here for all that they offer as far as the wires go I do not have access to my database right now but I do not believe that the vue has changed at all since it came out so the 06 is more then likely the same.
Chris Luongo
Platinum - Posts: 3,746
Posted: December 14, 2007 at 12:53 PM / IP Logged
I would just get an Audiovox AS-TCBM bypass box, and a blank "circle-plus" transponder key from howardkeys.com or eBay.....probably cheaper than a module.
I would have gone with a one-button remote starter instead of the APS-620. You can hook up keyless, but the aftermarket unit has no way to control the factory alarm.
Unless maybe something from idatalink.ca will control the alarm, I'm not sure about that.
The new Vue has the same new-style GM ignition wiring as many other cars......2007 Silverado/Suburban, Equinox, 2008 Cadillac CTS, ......they're all pretty much the same, so try searching for one of those.
NowYaKnow
Gold - Posts: 1,217
Posted: December 14, 2007 at 5:34 PM / IP Logged
The XK01 will control the locks and OEM alarm, and the XK06 will do the passlock. Obviously both modules are gonna be pretty pricey though. Not much of a diagram needed the lights are neg at the switch, horn is neg, brake positive in the drivers door sill, constant power in the drivers door sill, the rest is controlled from the modules. I'm with Chris I would go with a one button basic start on the new GM's.
Mike
wiretapper
Copper - Posts: 166
Posted: December 14, 2007 at 9:31 PM / IP Logged
NowYaKnow wrote:
The XK01 will control the locks and OEM alarm.
Mike
Not on an '04, I can tell you that much. Arm/disarm is fact remote only. Just did one. BUT......I also set the remote start "aux" input trigger to 3 lock pulses and it now starts with the fact. AND aftermarket remote.
mbaudio06
Copper - Posts: 60
Posted: December 19, 2007 at 12:50 PM / IP Logged
Can i possibly get a wiring diagram? All my resources go only up 06.
tedmond
Gold - Posts: 4,610
Posted: December 19, 2007 at 2:49 PM / IP Logged
hey, i got the diagram for the 2008 vue. just click the link, wait 20 seconds untill u see download. click download on, its a PDF and thats it.
http://www.4shared.com/file/32513044/54f3824f/2008_Saturn_Vue.html
*theone*
Copper - Posts: 68
Posted: December 19, 2007 at 3:32 PM / IP Logged
I tried using the XK06 on an 07 ION and it only worked some of the time. When it didn't work the key would not work as well. There is a way the use a couple of relays and a resistor, I'm not 100% if an 08 is the same, but worth looking into.
Friday, June 7, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
