2007 chrysler aspen, remote start
Msp541
Copper - Posts: 52
Posted: December 16, 2007 at 8:40 PM / IP Logged
Hi All;2007 chrysler aspen, remote start - Last Post -- posted image.
Does anyone have the wiring diagram for the 2007 CHRYSLER ASPEN vehicle? I am looking to install a remote starter in my truck and need the correct wiring diagram, i have the bypass kit for the security bypass and the doorlock feature. Any help would be greatly appreciated, thanks!
Twelvoltz
Platinum - Posts: 2,384
Posted: December 16, 2007 at 8:56 PM / IP Logged
Audiovox Lists:
          #512291: 2007 CHRYSLER ASPEN 4DR SUV WITH 4.7L ENGINE AND ALPINE® 8-SPEAKER AUDIO SYSTEM
     Audio/Mobile Video
     WIRE          COLOR          POLARITY          LOCATION
     Battery          GRAY/RED          (+)          RADIO HARNESS
     Accesory
               THE RADIO HARNESS DOES NOT PROVIDE A SWITCHED POWER SOURCE.
     Ground          BLACK          (-)          RADIO HARNESS
     Illumination          BLACK / YELLOW          (+)          RADIO HARNESS
     Dimmer          ORANGE          (+)          RADIO HARNESS
     LF Speaker (+)          DARK GREEN
     LF Speaker (-)          BROWN / RED
     RF Speaker (+)          BROWN / YELLOW
     RF Speaker (-)          BROWN / LIGHT BLUE
     LR Speaker (+)          WHITE
     LR Speaker (-)          DARK BLUE/RED
     RR Speaker (+)          BROWN / WHITE
     RR Speaker (-)          BROWN / ORANGE
     Steering Cntrls          YES
     Speed Cntrl          YES
     Radio Security          YES
     Security
     Battery          LIGHT BLUE/RED          (+)          IGNITION SWITCH HARNESS
     Ignition 1          PINK/GRAY          (+)          IGNITION SWITCH HARNESS
     Starter 1          GRAY / YELLOW          (+)          MODULE ON DRIVER FENDER
               NOT FOR REMOTE START
     All Door Trigger          YELLOW/ORANGE          (+)          IN HARNESS IN DRIVER KICKPANEL
     Domelight Super          YELLOW/ORANGE          (+)          AT COURTESY LIGHT UNDER DASH
     LF Latch          VIOLET          (-)          AT DRIVER DOOR MODULE
     RF Latch          VIOLET/WHITE          (-)          AT PASSENGER DOOR MODULE
     LR Latch          VIOLET/GRAY          (-)          IN HARNESS IN DRIVER KICKPANEL
     RR Latch          VIOLET / YELLOW          (-)          IN HARNESS IN DRIVER KICKPANEL
     Trunk Trigger          VIOLET/ORANGE          (-)          IN HARNESS IN DRIVER KICKPANEL KICKPANEL
     Hood Trigger          VIOLET/LIGHT BLUE          (-)          AT VEHICLE HOOD PIN SWITCH
     Parking Lights          PINK/RED          (-)          AT VEHICLE PARKING LIGHT SWITCH
               USE A 1.1K OHM RESISTOR, MUST ISOLATE FROM THE LIGHT SWITH DUE TO A REST RESISTANCE,
     Convenience
     Headlights-Lo          PINK/RED          (-)          AT VEHICLE HEADLIGHT SWITCH
               (-) THROUGH 600 OHM RESISTOR, MUST ISOLATE FROM SWITCH WITH A RELAY
     All Hazrd Lights          WHITE/ DARK BLUE          (-)          AT VEHICLE HAZARD SWITCH
               MUST USE 120 OHM RESISTOR AND ISOLATE FROM THE SWITCH DUE TO A REST RESISTANCE ON THE SWITCH
     LF Hazrd Bulb          WHITE/ LIGHT GREEN          (+)          AT FRONT LEFT DIRECTIONAL LIGHT
     RF Hazrd Bulb          WHITE/ TAN          (+)          AT FRONT RIGHT DIRECTIONAL LIGHT
     LR Hazrd Bulb          WHITE/ DARK GREEN          (+)          AT REAR LEFT DIRECTIONAL LIGHT
     RR Hazrd Bulb          VIOLET/GRAY          (+)          AT REAR RIGHT DIRECTIONAL LIGHT
     Wipers-Lo          BROWN / WHITE          (+)          AT VEHICLE WIPER MOTOR
     Wipers-Hi          BROWN / ORANGE          (+)          AT VEHICLE WIPER MOTOR
     Parking Brake          DARK GREEN / WHITE          (-)          AT VEHICLE PARKING BRAKE SWITCH
     Trnk Release          VIOLET/TAN          (-)          AT TRUNK RELEASE SWITCH
     Seat Mem 1          LIGHT GREEN/ DARK BLUE          (-)          AT DRIVER DOOR MODULE
               USE A 7K OHM RESIRTOR FOR SEAT MEMORY 1
     Seat Mem 2          LIGHT GREEN/ DARK BLUE          (-)          DRIVER DOOR MODULE
               SAME WIRE AS SEAT MEMORY 1, USE A 2K OHM RESISTOR FOR SEAT MEMORY 2
     Remote Start
     Accessory 1          VIOLET/BROWN          (-)          IGNITION SWITCH HARNESS
               (-) THROUGH 560 OHM RESISTOR
     Starter 2          VIOLET/BROWN          (-)          IGNITION SWITCH HARNESS
               (-) THROUGH 180 OHM RESISTOR
     Anti-Theft Type          DAIMLER SENTRY KEY® VEHICLE IMMOBILIZER
     Anti-Theft Descript          THE KEY SENDS AN RF SIGNAL TO THE BCM MODULE THROUGH AN ANTENNA LOCATED AROUND THE IGNITION CYLINDER
     Key Sense          VIOLET/BROWN          (-)          IGNITION SWITCH HARNESS
               SAME AS STARTER 2 AND ACCESSORY WIRE, USE 8.5K OHM RESISTOR
     Neutral Safety          .          .          .
     Tachometer          BLACK/ GRAY          (-)          AT IGNITION COIL
     Speed Sense          DARK GREEN/ BROWN          (AC)          AT PCM MODULE ON PASSENGER FENDER UNDER HOOD
     Brake Lights          WHITE/ TAN          (+)          AT SWITCH ABOVE BRAKE PEDAL
     Reverse Lights          WHITE/ RED          (+)          AT VEHICLE FUSEBOX
     Horn          DARK GREEN/ VIOLET          (+)          IN HARNESS AT VEHICLE HORN
     Modules
     WIRE          LOCATION
     Please select another category
     Doorlocks/Windows
     Power Unlock          LIGHT BLUE/ORANGE          (-)          AT DRIVER DOOR MODULE
               USE 100 OHM RESISTOR
     PowerLock          LIGHT BLUE/ORANGE          (-)          AT DRIVER DOOR MODULE
               USE 330 OHM RESISTOR
     LF Window Up          ORANGE / LIGHT BLUE          (AC)          AT DRIVER DOOR MODULE
     LF Window Dn          ORANGE / DARK BLUE          (AC)          AT DRIVER DOOR MODULE
     RF Window Up          DARK BLUE/ORANGE          (AC)          AT PASSENGER DOOR MODULE
     RF Window Dn          LIGHT GREEN/ ORANGE          (AC)          AT PAGGENGER DOOR MODULE
     LR Window Up          DARK BLUE/LIGHT GREEN          (AC)          IN HARNESS IN DRIVER KICKPANEL TO DOOR
     LR Window Dn          DARK BLUE/PINK          (AC)          IN HARNESS IN DRIVER KICKPANEL TO DOOR
     RR Window Up          TAN/WHITE          (AC)          IN HARNESS IN DRIVER KICKPANEL TO DOOR
     RR Window Dn          DARK BLUE/ORANGE          (AC)          IN HARNESS IN DRIVER KICKPANEL TO DOOR
     Note: Audiovox makes no representation or warranty with respect to the above information including its accuracy, completeness, or its freedom from third parties' proprietary rights. Audiovox disclaims all liability or responsibility for errors or omissions therein or any decision made by the recipient in reliance thereon. The installer must verify any circuitry with the proper test equipment prior to installation.
Friday, June 7, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
