07 Jeep Compass & 08 Nissan Sentra Alarm/RS/Stereo Wiring
p/t installer
Member - Posts: 29
Posted: December 23, 2007 at 6:55 PM / IP Logged
I need wiring diagrams for 2007 Jeep Compass and 2008 Nissan Sentra. Any help out there thanks.
Twelvoltz
Platinum - Posts: 2,384
Posted: December 23, 2007 at 7:03 PM / IP Logged
Audiovox Lists:
          #510154: 2007 JEEP COMPASS 4DR SUV WITH 2.4L ENGINE AND BOSTON ACOUSTICS® AUDIO SYSTEM
     Audio/Mobile Video
     WIRE          COLOR          POLARITY          LOCATION
     Battery          RED / LIGHT BLUE          (+)          RADIO HARNESS
     Accesory          WHITE/ ORANGE          (DATA)          RADIO HARNESS
               THIS VEHICLE USES THE CAN DATA SYSTEM FOR ACCESSORY TURN ON, USE AN ADAPTOR OR RUN A WIRE TO THE FUSEBOX
     Ground          BLACK / YELLOW          (-)          RADIO HARNESS
     Power Antenna          GRAY/RED          (+)          RADIO HARNESS
     LF Speaker (+)          GRAY/VIOLET
               THESE WIRES SUPPLY THE AUDIO SIGNAL TO THE AMPLIFIER
     LF Speaker (-)          GRAY / YELLOW
     RF Speaker (+)          DARK GREEN/ VIOLET
     RF Speaker (-)          DARK GREEN/ YELLOW
     LR Speaker (+)          DARK GREEN/ DARK BLUE
     LR Speaker (-)          DARK GREEN/ BROWN
     RR Speaker (+)          GRAY/DARK BLUE
     RR Speaker (-)          GRAY/ORANGE
     Amp Location          BEHIND RIGHT SIDE TRIM PANEL IN CARGO AREA
     Security
     Battery          RED / ORANGE          (+)          IGNITION SWITCH HARNESS
               THIS WIRE ONLY SUPPLYS 10 AMPS OF CURRENT, FOR ANY HIGH CURRENT NEEDS GO DIRECTLY TO THE BATTERY
     Ignition 1          PINK/WHITE          (+)          IGNITION SWITCH HARNESS
     Starter 1          YELLOW/GRAY          (+)          IN MODULE ON DRIVER FENDER UNDER HOOD
               NOT FOR REMOTE START
     All Door Trigger          USE LATCH WIRES
               USE ALL TRIGGERS AND DIODE ISOLATE EACH WIRE
     Domelight Super          YELLOW/WHITE          (+)          IN HARNESS IN DRIVER A PILLAR
     LF Latch          PURPLE / BLACK          (-)          DRIVERS KICK PANEL
               ALL OF THE LATCH WIRES ARE LOCATED IN A LARGE BLACK CONNECTOR ABOVE THE DRIVERS KICK
     RF Latch          PURPLE / WHITE          (-)          DRIVERS KICK PANEL
     LR Latch          UNKNOWN          (-)          PIN 24 OF SAME CONNECTOR
     RR Latch          PURPLE / YELLOW          (-)          DRIVER KICK PANEL
     Trunk Trigger          PURPLE / ORANGE          (-)          DRIVERS KICK PANEL
     Hood Trigger          PURPLE / LLIGHT BLUE          (-)          AT FACTORY PIN SWITCH
     Alarm Disarm          PURPLE / BROWN          (-)          IGNITION SWITCH
               8.5K RESISTOR THROUGH (-) ON THE PURPLE / BROWN MUX WIRE AT IGNITION SWITCH.
     Parking Lights          WHITE/ PURPLE          (+)          DRIVERS KICK PANEL
               ALSO AT MODULE UNDER HOOD ON DRIVER FENDER
     Convenience
     Parking Brake          DARK GREEN / WHITE          (-)          AT PARKING BRAKE SWITCH
     Remote Start
     Accessory 1          PURPLE / BROWN          (-)          IGNITION SWITCH HARNESS
               ACCESSORY IS (-) THROUGH A 600 OHM RESISTOR, SAME WIRE IS STARTER 2 AND KEYSENSE,
     Starter 2          PURPLE / BROWN          (-)          IGNITION SWITCH HARNESS
               STARTER 2 IS (-) THROUGH A 180 OHM RESISTOR, SAME WIRE IS ACCESSORY AND KEYSENSE,
     Anti-Theft Type          DAIMLER SENTRY KEY® VEHICLE IMMOBILIZER
     Anti-Theft Descript          THE KEY SENDS AN RF SIGNAL TO THE BCM MODULE THROUGH AN ANTENNA LOCATED AROUND THE IGNITION CYLINDER
     Key Sense          VIOLET/BROWN          (-)          IGNITION SWITCH HARNESS
     Tachometer          ANY UNCOMMON WIRE COLOR          (AC)          ANY IGNITION COIL
               NOT BROWN / GREY OR BROWN / YELLOW
     Brake Lights          DARK GREEN / WHITE          (+)          DRIVERS KICK PANEL
     Reverse Lights          WHITE/ LIGHT GREEN          (+)          DRIVERS KICK PANEL
     Horn          DARK GREEN/ PURPLE          (-)          STEERING COLUMN HARNESS
     Modules
     WIRE          LOCATION
     Please select another category
     Doorlocks/Windows
     Door Lock Circuit          ONE WIRE SYSTEM
     Power Unlock          LIGHT GREEN/ DARK GREEN          (-)          DRIVERS KICK PANEL
               UNLOCK IS (-) THROUGH A 100 OHM RESISTOR, SAME WIRE FOR LOCK,
     PowerLock          LIGHT GREEN/ DARK GREEN          (-)          DRIVERS KICK PANEL
               LOCK IS (-) THROUGH A 330 OHM RESISTOR, SAME WIRE FOR UNLOCK,
     Note: Audiovox makes no representation or warranty with respect to the above information including its accuracy, completeness, or its freedom from third parties' proprietary rights. Audiovox disclaims all liability or responsibility for errors or omissions therein or any decision made by the recipient in reliance thereon. The installer must verify any circuitry with the proper test equipment prior to installation.
AND:
          #513691: 2008 NISSAN SENTRA 4DR SEDAN WITH 2.0L ENGINE AND 4-SPEAKER AUDIO SYSTEM
     Audio/Mobile Video
     Battery          PINK          (+)          RADIO HARNESS
     Accesory          BLUE          (+)          RADIO HARNESS
     Ground
               THIS RADIO GROUNDS THROUGH THE CHASSIS MOUNTING BRACKETS.
     Illumination          RED / GREEN          (+)          RADIO HARNESS
     Dimmer          RED / YELLOW          (+)          RADIO HARNESS
     LF Speaker (+)          PINK
     LF Speaker (-)          BLUE
     RF Speaker (+)          WHITE
     RF Speaker (-)          BLACK
     LR Speaker (+)          LIGHT GREEN
     LR Speaker (-)          VIOLET
     RR Speaker (+)          BLUE
     RR Speaker (-)          PINK
     Steering Cntrls          NO
     Speed Cntrl          NO
     Radio Security          YES
     Security
     Battery          GREEN          (+)          IGNITION SWITCH HARNESS
     Ignition 1          YELLOW          (+)          IGNITION SWITCH HARNESS
     Starter 1          WHITE          (+)          IGNITION SWITCH HARNESS
     All Door Trigger
               YOU MUST DIODE ISOLATE BOTH TRIGGERS TO MONITOR ALL DOORS.
     LF Latch          RED / WHITE          (-)          IN HARNESS IN DRIVERS KICKPANEL
     RF Latch          RED / WHITE          (-)          IN HARNESS IN PASSENGER KICKPANEL
     LR Latch          BROWN          (-)          IN HARNESS IN PASSENGER KICKPANEL
               MAY ALSO BE BROWN / WHITE
     RR Latch          RED / WHITE          (-)          IN HARNESS IN PASSENGER KICKPANEL
               MAY ALSO BE RED
     Trunk Trigger          RED / SILVER DOTS          (-)          AT LIGHT IN TRUNK
               MAY ALSO BE WHITE/ GREEN IN HARNESS IN DRIVER KICKPANEL
     Alarm Disarm
               THERE IS AN OPEN PIN IN THE KEYLESS ENTRY CONNECTOR NEXT TO THE VIOLET TRUNK RELEASE WIRE, THIS WILL DIS ARM THE FACTORY ALARM IF EQUIPPED WITH A (-) PULSE
     Parking Lights          RED          (+)          IN HARNESS IN DRIVER KICKPANEL
     Convenience
     Headlights-Lo          GREEN/ ORANGE          (+)          AT VEHICLE LIGHT SWITCH
     Trnk Release          RED          (+)          IN HARNESS IN DRIVER KICKPANEL TO REAR
     Remote Start
     Accessory 1          RED          (+)          IGNITION SWITCH HARNESS
     Anti-Theft Type          NISSAN NVIS® VEHICLE IMMOBILIZER
     Key Sense          RED / BLUE          (+)          IGNITION SWITCH HARNESS
               **THIS WIRE MUST BE ENERGIZED FOR REMOTE START**
     Tachometer          RED          (-)          AT FUEL INJECTOR
     Speed Sense          VIOLET/RED          (AC)          IN HARNESS UNDER CENTER CONSOLE
     Brake Lights          RED / GREEN          (+)          AT SWITCH ABOVE BRAKE PEDAL
     Horn          GREEN          (-)          IN HARNESS HIGH IN DRIVER KICKPANEL
     Modules
     WIRE          LOCATION
     Doorlocks/Windows
     Power Unlock          PINK          (-)          IN HARNESS IN DRIVER KICKPANEL TO DOOR
     PowerLock          RED          (-)          IN HARNESS IN DRIVER KICKPANEL TO DOOR
