05 pontiac g5 remote start wiring
red85
Member - Posts: 31
Posted: January 05, 2008 at 3:28 PM / IP Logged
Hi there.  Does anyone have the wiring guide for a remote starter applicatin for an 05 Pontiac G5?
Phil
Moderator - Posts: 12,488
Posted: January 05, 2008 at 11:36 PM / IP Logged
Pontiac 2005 Pursuit 4DR Sedan
(Remote Start / Security / GPS)
Remote start / security / GPS
Wire/Function Colour Location/Description Polarity
PASSIVE ANTI-THEFT YES TRANSPONDER    SEE NOTES
12 VOLTS RED / black C3 plug on BCM in center console    +
   The BCM is located in the passenger side of the center console. It has 4 plug running left to right C1 (72-pin), C2(72-pin), C3(40-pin) & C4 (not used).
IGNITION Yellow Ignition switch harness or C4 plug on BCM    +
ACCESSORY Brown Ignition switch harness or C4 plug on BCM    +
STARTER SEE NOTES
   No connection is required for remote start. When accessory shuts down during the start cycle the vehicle will crank automatically.
TACH SIGNAL Use an injector wire
FUEL INJECTOR Opposite from Pink At any injector on engine    AC
LOCK White In driver's kickpanel or C1 plug on BCM    -
   1-wire system. Ground (-) to lock and ground through 1.5K resistor to unlock. The BCM is located in the passenger side of the center console. It has 4 plug running left to right C1 (72-pin), C2(72-pin), C3(40-pin) & C4 (not used).
UNLOCK White In driver's kickpanel or C1 plug on BCM    -
DOORPIN SEE NOTES
   Driver's door (Gray/black) and Passenger door (Tan/white) are both found at the BCM on the passernerg side of the center console in the C1 (72-pin plug).
TRUNK PIN ORANGE / black C1 plug on BCM in center console    -
TRUNK RELEASE Tan C2 plug on BCM in center console    -
FACTORY ARM With OEM remote only
FACTORY DISARM With OEM remote only
BRAKESWITCH Lt.blue At switch above brake pedal    +
PARKLIGHTS Brown In driver's kickpanel or C1 plug on BCM    +
HAND BRAKE Lt.blue C1 plug on BCM in center console    -
HORN Tan Ignition switch or C2 plug on BCM    -
CLUTCH SWITCH Yellow At clutch switch    Type 1
REVERSE LIGHTS Lt.green Under driver's side running board    +
PASSLOCK DATA White Ignition switch harness    DATA
PASSLOCK GROUND WHITE/ black Ignition switch harness    -
red85
Member - Posts: 31
Posted: January 06, 2008 at 5:42 AM / IP Logged
So there's no connection for the crank/starter wire at all?  Are all these wires the same colour at the BCM as they are at the ignition harness?  It would certainly make for a cleaner installation if I could put all this stuff in the center console.
Posted: January 06, 2008 at 10:02 AM / IP Logged
It is recommended that you go to the ignition for your ignition wires ( especially for the immobilizer bypass ).
Monday, June 3, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
