07 c6 vette fg box
nelsonhays
Posted: May 12, 2008 at 4:54 PM / IP Logged
tiewan wrote:
what is used to make the lip around the speaker ring?
that's low heat plastic - http://74.175.101.66/dealer/searchresult.asp?Cartid={B96186FBEVEREST-2639-48F4-9003-FDFE1B7A468E}
Select Products is one of 100 places to buy it.
it's great for making a flush ring with half the wood cutting time.
bellsracer
Silver - Posts: 703
Posted: May 16, 2008 at 12:28 PM / IP Logged
Can't be LH-ABS... it looks more like HDChipboard to me... Look at the staples. I use this stuff all the time for inserts and embossing on hard surfaces. 1/8" and when bent, it becomes strong enough to do thi kind of application. It's like flexible MDF. Easy to work with to.
Jimmy 2 Times
Copper - Posts: 67
Posted: May 16, 2008 at 3:45 PM / IP Logged
why not use mdf speaker rings?  I have never used plastic, is it easier to work with?
bellsracer
Silver - Posts: 703
Posted: May 18, 2008 at 1:36 PM / IP Logged
It depends on the application and what finish you are looking for... It's more of an individual installer preference. Unlike MDF, plastics don't breathe so you get a better seal. If you soak resin in, then MDF seals like plastic, but tends to be bulky. Chipboard is like MDF in thin layers, but soak in enough resin, it'll seal well. Whichever way you go, as long as the form is in a curve, they can be strong enough for the application.
xsdbs
Member - Posts: 8
Posted: May 20, 2008 at 12:33 PM / IP Logged
tiewan wrote:
so i guess no one knows what is used to make the lip?
The trim ring is made from weather resistant cardboard. you can get it at most ulpostery supplies. they use it alot for making door panels. oh yeah the shiny things are staples. ( just funin' on the last part, nothing personal )
bellsracer
Silver - Posts: 703
Posted: May 24, 2008 at 9:59 PM / IP Logged
weather resistant cardboard=chipboard. Shiny's = Staples. I WIN! What's my prize?
§^-^§v
