sealing a blow through enclosure
94chevytruck
Member - Posts: 21
Posted: July 07, 2008 at 4:59 PM / IP Logged
Saw a topic about this but it was closed.
This is a good and relatively inexpensive way to seal the opening of a blow through enclosure for a sub box in the bed of a truck. its the same way one stereo shop wanted to charge me a couple hundred dollars to do. just be sure you buy quality materials and you should be good
sealing a blow through enclosure - Last Post -- posted image.
If it aint broke...fix it till it is!
Platinum - Posts: 13,726
Posted: July 07, 2008 at 7:01 PM / IP Logged
Did you leave some slack in the vinyl to allow for the flex between the cab and the bed?
