resistor value
ikethegoalie
Copper - Posts: 79
Posted: July 23, 2008 at 7:24 AM / IP Logged
alright guys, I have never been particularly good with resistors and calculating values so I am just lookin for some help
For my passlock bypass i need 936 ohms resistance value. What I need to know is what resistor(s) to use because I have not seen a 936 ohm resistor outright
Also, what level of tolerance is there in the pass lock system, for example I do not want to be using 5% resistors, which would equal a potential fluctuation of 46.8 ohms. I would ideally want to us 1% resistors but they ca be kind of difficult to find, and its tough ordering them online, .90 cents in resistors,11 dollars shipping.
any input would be helpful
tedmond
Gold - Posts: 4,610
Posted: July 23, 2008 at 9:11 AM / IP Logged
you can use a Trim Pot and adjust accordingly. I suggest you fork out the 25 dolalrs to purchase a databypass. When using resistors, in the cold, the resistance changes and could cause the system to lockout. WHen using data bypass, you dont have to worry about resistance change as the bypass will do just that.
ikethegoalie
Copper - Posts: 79
Posted: July 23, 2008 at 9:15 AM / IP Logged
the problem was I have a 556lw in there now that is giving me problems. Is there another bypass company that comes highly recommended?
chriswallace187
Gold - Posts: 1,661
Posted: July 23, 2008 at 11:38 AM / IP Logged
What kind of car is this first off?
C Renner's Auto Electronix
Sunday, June 9, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
