98 grand cherokee module required?
misterjimbo
Silver - Posts: 535
Posted: October 22, 2008 at 9:03 AM / IP Logged
I looked up the sheet in the 12volts database and it did not say if a module was required for either locks or an immobilizer.
As A back up I always search the forum and I see a lot of posts for people using modules. Do I need them or are people just using them to simplify installation?
megaman
Copper - Posts: 385
Posted: October 22, 2008 at 9:41 AM / IP Logged
Yes, 455T from DEI is required for the door lock operation.  Also, you'll need an immobilizer bypass if the plastic on your key is grey.  If it's black, then no immobilizer bypass is required, but you will still need the door lock interface for keyless entry.
Flatlandfreak
Copper - Posts: 48
Posted: October 22, 2008 at 10:14 AM / IP Logged
98 Grand will most certainly have immobilizer, as well as the lock bypass.  You CAN get away without the lock bypass, but will need to go into the driver's door to do the locks and it's a pain in the butt, just buy the bypasses
I Like Peanut Butter!
misterjimbo
Silver - Posts: 535
Posted: October 22, 2008 at 12:14 PM / IP Logged
Thanks guys.
chriswallace187
Gold - Posts: 1,661
Posted: October 22, 2008 at 3:09 PM / IP Logged
'98 will NOT have an immobilizer. '99 and up started with that.
C Renner's Auto Electronix
Flatlandfreak
Copper - Posts: 48
Posted: October 22, 2008 at 3:34 PM / IP Logged
AAAHHH....your right.  I had a brain fart.  Sorry.  Was thinking it was 98+.  Sorry!
