hyundai elantra 2006
Welcome Guest :)
ks audio
Member -
Posted: January 04, 2009 at 1:59 PM / IP Logged
I am looking for a wiring diagram for self start for this car my books go to a 2005 I am thinking that they are the same but not sure. oh and does it need a by pass box with the key in it I am guessing no. thanks for the help
ksaudio
Platinum -
Posted: January 04, 2009 at 3:08 PM / IP Logged
oneohm
Member -
Posted: January 04, 2009 at 9:46 PM / IP Logged
12volts | red and pink (common 40A) |
| | ignition harness |
Starter | white | + | ignition harness |
Ignition | orange | + | ignition harness |
Power Lock | pink | - | dr kick or ETACM, 20 pin plg, pin 20 |
Power Unlock | yellow/orange | - | dr kick or ETACM, 20 pin plg, pin 14 |
Lock Motor | gray | 5wi | driver kick or door lock control mod |
Unlock Motor | RED / orange | 5wi | driver kick or relay R of fuse box |
Disarm Defeat | green | 5wi | driver kick or door lock control mod |
Parking Lights+ | GREEN/ orange (L), pink (R) | + | fuse box, blk 14 pin plg, pins 8, 14 |
Parking Lights- | blue | - | switch or ETACM, 16 pin plug, pin 14 |
Hazards | green (only w/fac. alarm) | - | ETACM, 12 pin plug, pin 8 |
Turn Signal(L) | yellow/orange | + | turn signal switch |
Turn Signal(R) | blue | + | turn signal switch |
Door Trigger | yellow | - | dr kick or ETACM, 20 pin plg, pin 18 |
Dome Supervision | yellow or white | - | fusebox or ETACM, 20 pin plg, pin 11 |
Trunk/Hatch Pin | green to GREEN/ black | - | dr kick or ETACM, 20 pin plg, pin 10 |
Hood Pin | GREEN/ black | - | pin sw or ETACM, 12 pin plug, pin 7 |
Trunk/Hatch Release | N/A | | |
Power Sliding Door | N/A | | |
Factory Alarm Arm | factory remote only | | |
Factory Alarm Disarm | factory remote only | | |
Disarm No Unlock | with ign, acc, and key sense | | |
Tachometer | blue | ac | PCM, 81 pin plug, pin 66 or cluster |
Horn Trigger | red | - | horn switch |
Memory Seat 1 | N/A | | |
Memory Seat 2 | N/A | | |
Memory Seat 3 | N/A | | |
Monday, June 10, 2024
• Copyright © 1999-2024 the12volt.com, All Rights Reserved
• Privacy Policy & Use of Cookies
