1980 dodge d50, fiberglass project
maxxheadroom
Member - Posts: 12
Posted: January 14, 2009 at 12:44 AM / IP Logged
I have a 1980 Dodge D50 I put a For 302 in it initially I had a manual trans which worked great but later decided to swap it out for an auto. With that the stock center console no longer fit and the one that came with my B&M shifter just wasn't cutting it. So I decided to mold the two of them together and put some gauges in it as well. Let me know what you guys think! I started by trimming the two of the consoles so they would fit together in the truck, then I used spray foam to fill in all the gaps and temporarily glue them together until it was glassed. Then it was just a matter of glass and body filler. For the gauge pod I cut toilet paper tubes in half and fit them around the gauges then more spray foam and glass.
Here is the console pieces in place all trimmed
1980 dodge d50, fiberglass project - Last Post -- posted image.
The start of spray foam (Just an FYI fiberglass resign does not attack this stuff)
Big mess of foam waiting to be sanded down
Almost ready for glass now...
4 layers of glass later...
Toilet paper tube cut in half with another added in to get the right size then wrapped in fiberglass makes the gauge pods...
Here they are glued in place
Foamed ready to take shape
Sanded down ready for glass...
Glassed with body filler started, and you get an idea of what the gauges look like now...
Finally painted gauges installed...
Installed in the truck
I had the gauges out to get everything hooked back up, forgot to take a picture after. I will get one soon, I hope... Let me know what ya think!
wdtsf
jf-fiber
Posted: January 15, 2009 at 10:23 PM / IP Logged
Wow that looks great!
i didnt know that the foam could  be glassed. how hard does it got at the end?
very nice work...1980 dodge d50, fiberglass project - Last Post -- posted image.
Fernando
maxxheadroom
Member - Posts: 12
Posted: January 15, 2009 at 10:33 PM / IP Logged
Thanks, you mean how hard does the foam get? It's still a bit spongy but really not to bad at all. Sanding it by hand can be a bit of a pain because it wants to break off into chunks I ended up using a sanding disk and an angle grinder to ruff it out. Wasn't too bad though.
wdtsf
jf-fiber
Posted: January 16, 2009 at 6:35 AM / IP Logged
ill put that one on the list of my ideas!
Right now im making a 2005 corollas rear doors to install (2) 10'' woofers on each one. will be posting them soon.
But the foam thing is very good.
Fernando
boogeyman
Silver - Posts: 359
Posted: January 16, 2009 at 8:10 AM / IP Logged
 another great foam to use is floral foam the green stuff they put flowers into you can sand it veeeeeeery easy....they sell it at wal-mart
maxxheadroom
Member - Posts: 12
Posted: January 16, 2009 at 12:21 PM / IP Logged
I thought about going that route but it would not have filled in the gaps the way I needed.
wdtsf
