remote start f 250/ problem
kiteman
Copper - Posts: 98
Posted: February 01, 2009 at 10:33 PM / IP Logged
Actually, it's not the remote start that's not working.   Here's what I have. I've installed a Viper 5900 remote start, on a 08 F-250 Ford. I used the PKALL by pass mod. Everything works great, except when I remote start the truck, it starts but the horm starts a constant blow. It seems to be the fartory alarm, but i can't find a disarm wire, and dei's info shows NA.  Does anyone have any IDEAS???
davngr
Copper - Posts: 109
Posted: February 02, 2009 at 1:27 AM / IP Logged
once the horn starts going use the key on the door turn it to unlock and see if that makes it stop, if that don't work try inserting the key in the ignition.  if either of those work then just find the wire that triggers when you turn the key in the door or the key sense wire in the ignition switch and run the alarms *factory disarm* wire to it.    if it's a simple security system this will fix it, if it's one of the complicated ones you might need a CAN module or something.  i am not familiar with this car so i can't really advice you any further then this   good luck hope this post helps.
life is a comedy to think, a tragedy to feel
kiteman
Copper - Posts: 98
Posted: February 02, 2009 at 6:21 AM / IP Logged
Hey, Thanks for the advice, I will try both those today..
Monday, June 3, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
