small enclosure ,wood or fibreglass
justin lindhors
Posted: March 17, 2009 at 7:10 AM / IP Logged
car make ,nissan frontier crew cab le,i would like to fit 2 x rockford p8,under the rear seat,what would the best option be with limited space.
anyone done this before.thanks justin
davngr
Copper - Posts: 109
Posted: March 18, 2009 at 4:35 AM / IP Logged
if space is tight, i will usually make on side(top or bottom) of the box fiber glass at least.
depending on how confortable you are with fabrication.  you can also make a frame out of wood and then wrap it in material  as shown in the link below.     good luck with your project
https://www.the12volt.com/installbay/forum_posts.asp~TID~74519~PN~1
life is a comedy to think, a tragedy to feel
ca$ino
Copper - Posts: 67
Posted: March 19, 2009 at 2:56 PM / IP Logged
i personally would go with wood...
much easier to fab, and easier to adjust/fix if problems should arise.
Look twice, think thrice, 1 splice/ 1 slice!
This is a phrase i came up with and something i will now live by.
