sub woofer enclosure 2008 nissan titan
cdak7
Posted: March 19, 2009 at 1:38 PM / IP Logged
I have a 2008 Nissan Titan Crew Cab.  I want to install two JL Audio 10W1v2 subwoofers in an enclosure under the rear seat.   I listen to classic rock type music.  Any suggestions?   Thank you very much.
matt_993
Posted: March 19, 2009 at 2:34 PM / IP Logged
youre most likely going to have to raise your backseat a little bit. there are a couple post on here that deal with that.if i remember right there was a guy that did a under the seat box in a dodge ram. look for that one. as far as what type of enclosure, you are gonna be pretty limited due to space. youll most likely want to used an non-ported, sealed enclosure. your other option would be to go straight to JL Audio. they offer the stealth box that is designed just for your titan
i shine yall is just a slight gloss
