need to make a pulsed signal steady?
tanamu
Member - Posts: 10
Posted: April 15, 2009 at 8:03 PM / IP Logged
Hey all,
I have a 93 Nissan 240sx, and the door chime is pretty much the most annoying thing in the world. I have therefore replaced it with one from a VW that I liked, but the problem is that the VW's door chime requires a constant 12v signal to stay on, whereas the stock Nissan chime is just an electric bell, so it takes a pulsed (square wave I guess) signal.
The problem is I'm not sure how to turn that pulsed signal (probably around 1-2 Hz) into a steady 12v that will work with the new chime. I have tried using a pair of big capacitors, but they tend to make the chime stay on wayyyy too long, and one cap isn't enough. Also tried a 555 timer but it didn't really work either. So I decided to ask here and see if you guys have any ideas. :)
Thanks.
Platinum - Posts: 13,674
Posted: April 15, 2009 at 8:24 PM / IP Logged
Pulsed to Steady Output
If you have cornering lights and want them to come on only when your turn signal is on and you do not have a steady output, use the following for each side. This will give you a steady output while the turn signal is on. Increasing the size of the capacitor will give you a longer output if needed.
need to make a pulsed signal steady? - Last Post -- posted image.
tanamu
Member - Posts: 10
Posted: April 16, 2009 at 12:05 AM / IP Logged
Hm, you know I think I found that a long time ago when I first set out to do this.. but I was a little hesitant to try it because my relays tend to be pretty loud, and I don't really want to listen to the clicking every time the thing pulses.. but maybe I'll just go find a quieter one. :P
Thanks.
KPierson
Platinum - Posts: 3,527
Posted: April 16, 2009 at 5:05 AM / IP Logged
Pick up a reed relay - they are silent.  You will have to tweak your values with a reed relay though because their coils require drastically less current to stay energized (so theoretically you should be able to use a much smaller cap).
Kevin Pierson
Posted: April 16, 2009 at 6:05 AM / IP Logged
The relay will only click when it engages and will not click again until it disengages.  Remember the pulses have been converted to a non-pulsed output.  It will not click with each pulse of the input.
profuse007
Gold - Posts: 2,015
Posted: April 16, 2009 at 9:11 AM / IP Logged
used that same setup, not that clean but it works. the capacitor i got was pretty huge, ~0.5"dia-by-1.5".
Houston,TX
Friday, May 31, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
