2009 Subaru Impreza Sport Edition 5 Spd Alarm/RS Wiring
jbody
Member - Posts: 35
Posted: May 09, 2009 at 10:46 AM / IP Logged
as the topic states, might work on the car this weekend.
just looking for the wiring diagram for an remote starter and alarm.
also how to bypass the clutch.
thanks in advance.
t&t tech
Platinum - Posts: 2,608
Posted: May 13, 2009 at 5:50 PM / IP Logged
Remote Start info for the 09
     Battery          WHITE          (+)          IGNITION SWITCH HARNESS
     Ignition 1          GREEN          (+)          IGNITION SWITCH HARNESS
     Accessory 1          YELLOW          (+)          IGNITION SWITCH HARNESS
     Accessory 2          BLUE          (+)          IGNITION SWITCH HARNESS
     Starter 1          WHITE/ BLACK          (+)          IGNITION SWITCH HARNESS
     Starter 2          RED / BLACK          (+)          IGNITION SWITCH HARNESS
     Anti-Theft Type          UNIVERSAL IMMOBILIZER
     Anti-Theft Descript          THE KEY SENDS AN RF SIGNAL TO THE BCM MODULE THROUGH AN ANTENNA LOCATED AROUND THE IGNITION CYLINDER
     Key Sense          BLACK/ WHITE          (+)          IGNITION SWITCH HARNESS
     Tachometer          GRAY/RED          (AC)          IN HARNESS TO GAUGES
     Speed Sense          PINK/GREEN          (AC)          IN HARNESS TO GAUGES
     Parking Lights          BLACK/ WHITE          (+)          IN HARNESS IN DRIVER KICKPANEL
     Low Crr. Pk Lights          BLACK/ WHITE          (-)          AT BODY INTEGRATED UNIT UNDER DRIVER SIDE DASH
Alarm info for the 09
     Domelight Super          GREEN/ YELLOW          (-)          AT BODY INTEGRATED UNIT UNDER DRIVER SIDE DASH
     LF Latch          BLUE/ORANGE          (-)          AT BODY INTEGRATED UNIT UNDER DRIVER SIDE DASH
     RF Latch          BLUE/WHITE          (-)          AT BODY INTEGRATED UNIT UNDER DRIVER SIDE DASH
     LR Latch          YELLOW/WHITE          (-)          AT BODY INTEGRATED UNIT UNDER DRIVER SIDE DASH
     RR Latch          WHITE/ RED          (-)          AT BODY INTEGRATED UNIT UNDER DRIVER SIDE DASH
     Trunk Trigger          YELLOW/BLUE          (-)          AT BODY INTEGRATED UNIT UNDER DRIVER SIDE DASH
     Low Crr Pk Lights          BLACK/ WHITE          (-)          AT BODY INTEGRATED UNIT UNDER DRIVER SIDE DASH
commit your way to jehovah and he will act in your behalf. psalms 37:5
t&t tech
Posted: May 13, 2009 at 5:52 PM / IP Logged
this was posted by mr.idiot recently, test before you install.
Friday, May 31, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
