2001 lexus es300 wiring diagram
Welcome Guest :)
mazda 6t9
Member -
Posted: November 11, 2009 at 11:46 AM / IP Logged
Just need the diagram and to see if it needs a bypass module, thank you.
stjeric
Member -
Posted: November 11, 2009 at 7:48 PM / IP Logged
MODEL | YEAR(S) |
ES300 | 1998 -2001 |
KEY | T-HARNESS | IMMOBILIZER |
N/A | TOY-1 | LEXUS TRANSPONDER ANTI-THEFT SYSTEM, |
PART | COLOR | LOCATION | DIAGRAM |
12 VOLT CONSTANT | WHITE (+) and WHITE/ RED (+) | IGNITION SWITCH HARNESS | |
STARTER | RED (+) | IGNITION SWITCH HARNESS | |
STARTER 2 | N/A | | |
IGNITION 1 | BLACK / YELLOW (+) | IGNITION SWITCH HARNESS | |
IGNITION 2 | BLACK/ RED (+) | IGNITION SWITCH HARNESS | |
IGNITION 3 | N/A | | |
ACCESSORY /HEATER BLOWER 1 | BLUE/RED (+) | IGNITION SWITCH HARNESS | |
ACCESSORY /HEATER BLOWER 2 | N/A | | |
KEYSENSE | N/A | | |
PARKING LIGHTS ( - ) | GREEN (-) | @ STEERING COLUMN HARNESS | |
PARKING LIGHTS ( + ) | GREEN/ ORANGE (+) or GREEN/ BLACK (+) | @ BOTTOM OF FUSEBOX | |
POWER LOCK | DARK BLUE/WHITE (TYPE B) See NOTE *1 | @ THEFT MODULE See NOTE *1 | |
POWER UNLOCK | DARK BLUE (TYPE B) See NOTE *1 | @ THEFT MODULE See NOTE *1 | |
LOCK MOTOR WIRE | BLUE/RED (+) | @ ORANGE PLUG, BOTTOM OF FUSEBOX | |
DOOR TRIGGER | RED / WHITE (-), Requires Part #775 Relay | @ TOP OF FUSEBOX | |
DOMELIGHT SUPERVISION | USE DOOR TRIGGER, Requires Part #775 Relay | | |
TRUNK RELEASE | RED (-) | @ TRUNK RELEASE SWITCH | |
SLIDING POWER DOOR | N/A | | |
HORN | GREEN/ BLACK (-) | @ STEERING COLUMN HARNESS | |
TACH | GRAY See NOTE *2 | | |
WAIT TO START LIGHT | N/A | | |
BRAKE | GREEN / WHITE (+) | @ BOTTOM OF FUSEBOX | |
FACTORY ALARM DISARM | DISARMS WITH UNLOCK | | |
ANTI-THEFT | TRANSPONDER ANTI-THEFT SYSTEM, REQUIRES 791 BYPASS MODULE AND EXTRA IGNITION KEY | TRANSPONDER @ IGNITION SWITCH TUMBLER | |
NOTES |
NOTE *1 THE THEFT MODULE IS AT THE FRONT OF THE CENTER CONSOLE UNDER THE RADIO.THE LOCK WIRES ARE ABOUT 18 GAUGE.THEY WILL ONLY TEST WHILE TURNING KEY IN PASSENGER SIDE DOOR LOCK CYLINDER.NOTE *2 ON THE 6 CYLINDER MOTOR USE THE GRAY WIRE LOCATED AT THE IGNITOR ON A BRAKET IN FRONT OF DRIVERS SIDE STRUT TOWER.THE MODULE SAYS "DENSO" ON IT. |
Eric St-Jean
Sunday, June 9, 2024
• Copyright © 1999-2024 the12volt.com, All Rights Reserved
• Privacy Policy & Use of Cookies
