can i test remote start without an engine
slashman
Member - Posts: 14
Posted: December 13, 2009 at 4:59 AM / IP Logged
Hi,
I'm currently installing a viper 791xv with remote start, now the car currently does not have an engine as it is in bits.  I would like to make sure all the wiring is correct before I tape it all up.  So what I was wondering is can I somehow test it.  I have the fog demister and heater hooked up to the alarm module.  Am I out of luck?
Platinum - Posts: 13,677
Posted: December 13, 2009 at 5:13 AM / IP Logged
You can use a volt meter to verify that the start wire gets voltage for a brief time when a remote start attempt is made.  But that will not tell you for sure that it is working.  There are things that you can not check without an engine.  Immobiliser issues, tach issues key sense issues, Etc.  It would help a lot if we knew what kind of vehicle you had.
slashman
Member - Posts: 14
Posted: December 13, 2009 at 5:24 AM / IP Logged
It's a mid 1980s vehicle.  It's australian made so you wouldn't be familar with the vehicle.  It originally had a carby on it but have since converted it to fuel injection.  It's basic, no complicated electronics etc.
I guess if I could somehow simulate a tach single that would work?
Posted: December 13, 2009 at 5:44 AM / IP Logged
Following on from what Mr. I says all you would be doing is repeating some of the many batch or individual tests a competent company like DEI, Compustar or Audiovox would do anyway! There's no point in your exercise, you're wasting your time!
tedmond
Gold - Posts: 4,610
Posted: December 13, 2009 at 2:35 PM / IP Logged
im sure dei, compustar, etc all bench their units prior to shipping them out. So as howie said, its not worth the time to wire it up and test. Just wire it up to a car and see if it starts.
Saturday, June 8, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
