2004 bmw x3 park lights wire
rksterling
Member - Posts: 46
Posted: December 21, 2009 at 8:11 PM / IP Logged
I am looking for the wire for the park lights on a 2004 BMW X3. I found information stating it to be a brown wire at the light switch.
I have a ribbon cable wire coming from a module to the light switch. Do I need to use a wire in this ribbon cable or do I use one supplying the module. There are three brown wires feeding the module. I think they all have the same colored strip.
05gt
Silver - Posts: 628
Posted: December 21, 2009 at 8:41 PM / IP Logged
if you are looking at the ribbon cable, seperate the 4th one from the left, cut this wire in half and wire in a relay this will get your parklights going
rksterling
Member - Posts: 46
Posted: December 21, 2009 at 9:31 PM / IP Logged
Is the 4th wire left from the stripe on the ribbon cable. The plugs are numbered. Is it number 4 wire?
Does anyone have a description of what all ten of the wires do? I am having trouble with my dimmer not working.
05gt
Silver - Posts: 628
Posted: December 21, 2009 at 11:05 PM / IP Logged
if you pull out the light switch from the dash, the ribbon cable will still be attached, count 4 wires over from the left and that is the wire you need
sorry I don't have any other info on what these other wires do
