box building tips needed
b17si
Member - Posts: 14
Posted: April 06, 2010 at 2:21 PM / IP Logged
Im an installer not a carpenter. Pre fab boxes are so cheap and well built I havent had to build anything in years. I can whip out a sealed box with no problem but i cant remember how to get all the ported info.
I am doing a custom box build in a 69 fastback using 2 Alpine swr-1042D subwoofers. i have been on a few sites trying to figure out port area, length, volume, tuning frequency...blah blah blah. its all to damn confusing now. I have 1.8 cubic feet of net volume that is usable. Ported volume minimum is .7 cubic feet. two makes 1.4. I figure i will invert the subs to leave plenty of room in the box for the port. now i just need to figure out what the port size will be. I would like to use a square port thinking it would look better but everything converts for a round port. can someone help me get my head wrapped around this BS before i go nuts?
Adrenaline Motorsports of Naples
j.reed
Copper - Posts: 716
Posted: April 06, 2010 at 8:48 PM / IP Logged
http://support.alpine-usa.com/products/documents/OM_SWR-1042D.PDF Page 3 will have there optimal enclosure. These are for a single sub. Running 2 in that small an enclosure your best option IMO is sealed. Ported i would rather run just a single one of those then cram 2 in a what would really be too small enclosure. Sure they say that .8cu.ft. will work in that space ported but the results will not be great.
box building tips needed - Last Post -- posted image.
b17si
Member - Posts: 14
Posted: April 07, 2010 at 11:54 AM / IP Logged
thanks for the quick responce. i have been trying to talk this guy into a sealed enclosure for a week or two now. He designed a ported box where the ports were on the opposite side as the sub. i told him i wont do it and now he is wized. i figured i build him his ported box to "specs" using my expertise in this area. I may not be the best builder but i know what should and should not be done.
If he really wants this ported box i will have to build it in the car. where as the sealed box can be built in the shop and secured in place in the car. i can build panels to make it all blend and look like a show car, but he doesnt wanna hear it. if he was a customer id tell him to hit the road. but its the owner of the shop so i gotta do what he wants. F it! im getting paid either way
j.reed
Copper - Posts: 716
Posted: April 07, 2010 at 4:38 PM / IP Logged
do a sealed and a ported. Let him hear the sealed then go to the too small ported enclosure. Then you can say told you so.
