2nd starter wire 2002 nissan
hdriscoll
Member - Posts: 17
Posted: November 16, 2010 at 6:00 AM / IP Logged
I'll be installing a remote start in a 2002 Nissan Sentra. The vehicle wiring charts I have show a second starter wire. The wiring diagram for the car doesn't show this.
Is this car even equipped with one? I haven't taken the car apart and looked at the wiring yet.
Mike M2
Platinum - Posts: 2,652
Posted: November 16, 2010 at 6:37 AM / IP Logged
Directechs states there are 2 starter wires, BLACK/ white and BLACK / YELLOW.
Mike M2
Tech Manager
CS Dealer Services
Posted: November 16, 2010 at 11:17 AM / IP Logged
The poster's comment "is the vehicle even equipped with one" boggles the mind. Mike, you know where this is going don't you.
KPierson
Platinum - Posts: 3,527
Posted: November 16, 2010 at 3:12 PM / IP Logged
Unless IAAI has his crystal ball handy we'll never know for sure.
Grab your tech sheet and your volt meter and check it out.  If it is there, hook it up, if it isn't there do not worry about it.
Kevin Pierson
Mike M2
Posted: November 16, 2010 at 4:09 PM / IP Logged
What i would like to know is what's the difference between a "vehicle wiring chart" and a "wiring diagram for the car"....
Mike M2
Tech Manager
CS Dealer Services
Posted: November 16, 2010 at 4:46 PM / IP Logged
Mike I could be facetious and say a chart is not a diagramme, the correct term is wiring diagramme. Why do these amateurs ask all these deep meaningless questions sometimes weeks before they even lay their hands on the car to actually test before making in this case a stupid statement? If in 3 weeks time our poster would have said "I've found a second starter wire,this is my car this is my R/S, how do I enable the second starter" I'm sure we'd have helped him/her without the cynicism.
mpe235
Copper - Posts: 90
Posted: November 16, 2010 at 5:02 PM / IP Logged
Yes it has a second starter wire that you must connect or the car will have trouble starting in very cold weather. If your remote starter doesn't have a second starter output you will need to wire a relay to power that wire. Click on the relay link to the left side of this page for instructions on how to wire the relay.
Nissan Master Tech.
t&t tech
Platinum - Posts: 2,608
Posted: November 16, 2010 at 5:10 PM / IP Logged
Yes you have a second starter, BLACK / YELLOW being the colour.
Posted: November 16, 2010 at 5:13 PM / IP Logged
And you Darren need to empty your in-box!
t&t tech
Posted: November 16, 2010 at 5:16 PM / IP Logged
Ok howard will do.
Sunday, June 9, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
