factory amp
chaos7692
Member - Posts: 21
Posted: November 22, 2011 at 3:03 AM / IP Logged
Is it advisable to use a line out converter hooked up to the outs of a factory amp? Specifically a 2004 camry with navigation. I cant find much specs on the factory system. Without having the car right now to test, i dont know what the factory amps power rating is, but we want to go with an aftermarket amp and all new speakers but need to keep the factory nav. Any problems i should know about?
jseibold
Copper - Posts: 98
Posted: November 22, 2011 at 7:54 AM / IP Logged
it shouldn't be a problem.  I have used a Metra line output converter several times in Tahoe and Expedition.  I have tapped off the factory sub (which is being fed by the factory amp) and added aftermarket subs.....
chaos7692
Member - Posts: 21
Posted: November 22, 2011 at 11:29 PM / IP Logged
What should i expect for sound quality? the output from the amp could be crossedover already. What about completely eliminating the factory amp? Is that possible? I really cant find much about this year/model to determine whether or not it has an amp sense function.
addicted
Copper - Posts: 59
Posted: November 23, 2011 at 10:48 PM / IP Logged
there are many converters availible you can use, better quality converters can handle higher inputs and have a cleaner output. the lesser models tend to be less quality. i purchased a lesser converter for my gf's accel to run a pair of 8's. it had a low rating but there was no need for the expensive one. factory output was fairly low. adjust line output to the the amp.  but remember your tapping into the stock amps output power so take it into calculations in order to know which converter to buy. if quality is what your after the higher priced is the way to go for quality.
it calls me...
chaos7692
Member - Posts: 21
Posted: November 24, 2011 at 12:14 AM / IP Logged
Quality is an issue, i dont expect a huge improvement, but even with the cheap ones it couldnt sound worse than the factory system considering the tweeters are blown, or could it? All the info i find, is people trying to add subs. Im replacing the stock speakers, not adding subs, so if there is a problem with sq then it will be more noticible. Also there seems to be a fairly large gap in prices between cheap line out converters, and more advanced units like the cleensweep. Any suggestions less than $100 that have 4 channels, in and out?
chaos7692
Member - Posts: 21
Posted: November 24, 2011 at 2:57 AM / IP Logged
What do you think of this, seems to match what im looking for...
http://www......com/item_23357_PAC-SOEM-4.html
chaos7692
Member - Posts: 21
Posted: November 24, 2011 at 8:10 PM / IP Logged
Just noticed link didnt post right, its at ....
Platinum - Posts: 13,677
Posted: November 24, 2011 at 9:40 PM / IP Logged
Links to Ebay, and many online retailers are not allowed here.
Mike M2
Platinum - Posts: 2,652
Posted: November 25, 2011 at 9:13 AM / IP Logged
Just pull the nav and use the outputs off it, or use the inputs to the factory amp. This way you won't need a converter at all.....
Mike M2
Tech Manager
CS Dealer Services
Monday, June 10, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
