4 12s or 2 15s
the_jeweler
Member - Posts: 25
Posted: May 01, 2012 at 11:49 PM / IP Logged
I'm wondering which of these setups will yield the best results. 4 12" pioneer premier champion series 12, 4 kicker cvr 12s or 2 American bass xd 15s. I have about a grand Marquis so about 7 cubes to work with and I want the subs firing up. I have a 200 amp alt, big 3 already done, kinetic 1200 cell, 2012 photonic Brutus brz2400. Any help will greatly b appreciated
Life is what u make of it so make the best of it
DYohn
Platinum - Posts: 10,741
Posted: May 02, 2012 at 10:04 AM / IP Logged
By "best results" I assume you mean "get loudest"?  That's largely dependent on the enclosure, but just looking at the sensitivity specs for the woofers, the Pioneers are 2db more sensitive than the Kickers so you'd get better power utilization from them, and the 15's will move more air.  The enclosure will determine your net SPL though.  Is this a daily driver?
the_jeweler
Member - Posts: 25
Posted: May 02, 2012 at 10:25 AM / IP Logged
Correct on being the loudest. Sorry about that. But with any of the enclosures I would want the subs facing up and the enclosure vented, also pointing up as well. And yes this will b daily
soundnsecurity
Gold - Posts: 2,720
Posted: May 02, 2012 at 10:58 AM / IP Logged
its impossible to tell you which system will be louder because there are just too many variables to consider. my personal opinion is i tend to lean toward the simpler systems so i would go with the 2 15's.  kicker cvr's are cheap subs that dont hold up to abuse very well.
also its easier to design a box for 2 subs than 4 subs especially if you plan to use a ported box. and a proper box design will make or break your system. id doesnt matter how good or how many subs you have, if you dont have them in a well designed box your system wont be at its full potential.
DYohn
Posted: May 02, 2012 at 11:02 AM / IP Logged
Excellent advice.  I too would tend toward a dual 15's setup for a daily driver.
the_jeweler
Member - Posts: 25
Posted: May 02, 2012 at 11:55 AM / IP Logged
ok. Thanks for the advice. So would the subs that I am considering be the best "bang for buck" subs? My budget is about 200 per woofer, but I have heard the xds in a sealed enclosure before and they were pretty deep. Any other sub suggestiins
DYohn
Posted: May 02, 2012 at 12:02 PM / IP Logged
American Bass subwoofers are made for them by Eminence so they are good quality speakers.  I like the HD series, but not sure what they sell for these days.  I've never heard the XD that I know of.
sostok
Posted: September 20, 2012 at 3:10 AM / IP Logged
also the fact you will be splitting amp power only by two with the 15's and roughly 3.5cuft per basic 15 should be good..
